Full Version: [RELEASE] RAI TV (Video) Plugin - Italian Television
Pages: 1 2 3 4 5 6 7 8 9
This plugin scrapes the http://www.rai.tv site. It supports live tv channels and a very wide choice of videos on demand. It is, of course, mainly intended for the italian audience.
Disclaimers:
http://www.rai.tv offers two types of streams:
1) wmv on mms: and
2) real media on rtsp: and pnm:
Unfortunately DVDPlayer at the moment has problems with rtsp and doesn't even recognize pnm. The plugin warns you if a rtsp stream is requested and doesn't play it. At the moment the only way to play these streams is using an external player (e.g. VLC). You should modify the source, though (simple deletion of some lines, instructions are in the code) and add the external player to playercorefactory.xml.
Luckily, most of the videos use the wmv format and should play fine with DVDPlayer.
The plugin is tested with Dharma and Eden. It should work on Linux, iOs and ATV too, or so I'm told. I don't know if it works outside Italy. Use it at your own risk.
The link:
Version 1.1
Rai Uno, Due and Tre are missing, because they use smoothstreaming that is not supported by XBMC. Please, don't ask if they will be ever supported because I DON'T KNOW.
http://www.mediafire.com/?qf2wfv65a42cncf
testing Raiuno diretta on xbmc 9.11 on linux.
So far, great plugin !
I'll test more later
Thank you for your work !
Just downloaded and tested it on Ubuntu 9.10 (on Asus Notebook A7Vb) with XBMC 9.11: work perfectly.
Great plugin !
Thank you for your work, I will follow your work ! Wink
I noticed that, with appearently no reason, after a few streams get played XBMC freezes.
chareos: log, please.
and sorry: I'll do what I can but, as I said, I can't test it on Linux, Mac or XBox
I'll try again and eventually get a log in a few days
(btw: any chance you consider to try and make a skytg24 plugin ?)
chareos Wrote:(btw: any chance you consider to try and make a skytg24 plugin ?)
Unlikely.
ghizzu Wrote:This plugin scrapes the http://www.rai.tv site. It supports live tv channels and a very wide choice of videos on demand. It is, of course, mainly intended for the italian audience.
Disclaimers:
http://www.rai.tv offers two format of streams:
1) wmv on mms: and
The plugin is tested with 9.11 Camelot and Windows only. I can't test it on other systems. I don't know if it works outside Italy. Use it at your own risk. Let me know.
If you want you can add it to SVN Repo (I haven't access to it).
The link:
http://www.megaupload.com/?d=QU7SYMEW
Hi ghizzu,
i've testing your plugin into Linux Ubuntu 9.04 + vdr 1.7.9 + XBMC ltest SVn with VDPAU.
The streaming channels works fine all. The podcast....wait for a long time, but it start fine.
Great work!!!
I'm a programmer. If you want i can help you to test it on Linux workstation
Regards
Tu sei un genio! Proverò questo plugin sulla mia XBOX questa sera... speriamo bene!
Potete per caso fare qualcosa con VCAST che, per chi non lo sa, permette anche la registrazione dei filmati (e visione + canali podcast) da digitale terrestre?
HI Ghizzu,
il link di megaupload non funziona piu', come altro posso trovare il plug-in?
new version posted.
I am gonna test this (on Linux), my Italian is getting very rusty...
Ti farò sapere se funziona o no Wink.
for the RTSP problem, take a look here..
(non so se può esserti utile, ma magari lo è ....)
Thank you, but that post refers to rtMp, not rtSp (another matter entirely).
How do I install Rai.tv plugin in the version Dharma?
