2010-01-25, 22:36
I posted this in a response to http://forum.xbmc.org/showthread.php?tid...deo&page=9, but since it's been a whole day with no responses (yes, I am that impatient ) I'm posting it as a new thread here!
When I use XBMC, sound works fine, but no video shows up.
I'm running the standard version of XBMC 9.11 (just downloaded) on an ASUS mobo with a HD3200 GPU and X2 240e CPU.
Has there been any updates on how to fix this?
I've seen everything from changing Direct X to using some unspecified OpenGL version of XBMC, but I've yet to see where to get it?
Any tips appreciated!
As a side note, XBMC runs at less than 15fps in fullscreen (1080p) in the menus? Anything I can do to speed it up some?
There's plenty of CPU power available for it to use, if possible...
Cheers in advance!
System info:
XBMC version: 9.11 R26017 (Compiled: Dec 23, 2009)
OS: Windows 7 Professional
Ram: 2gb DDR2 @ 533mhz
CPU: Athlon II X2 240e
GPU: HD3200 (AMD 780G chipset)
Video driver: Windows 7 default driver & ATI 9.12. (Same problem with both)
A debug log (about 800kb):
http://www.megaupload.com/?d=5HCJX9Q2
Cheers in advance!
System info:
