Full Version: Going into standby on asrock ion330HT
I'm running xbmc over ubunto karmic on an asrock ion330HT-BD using the Transparency! skin (a it allows greater control over what happens when you hit the power switch than the default skin.)
My question is: How do I set the control/machine/xbmc system to put the machine into standby when I click the remote power button instead of either shutting down completely or minimizing the xbmc app (options under power saving in Transparency! skin.) ?
I'd like to put the machine to sleep and then wake it up again either by clicking the power button on the remote or the button on the machine.
Any ideas/leads appreciated.
Regards
no input except im keen to know this too. subscribed.
