Well, this is annoying, as all problems usually are. When I try to play HD movies XBMC (standalone) totally freeze up and I have to SSH into the system and kill the process. Sometimes it hangs even before I get any audio and video, sometimes it will start and play fine as long as I don't touch it, but if I stop or forward it will hang.
My TV shows are mostly HD content and do not seem to have this problem. Also, my SD movies play fine. All my HD content is on local disks, SD content is on NAS. Everything works fine if I start them from the "Files" menu instead of the library.
I'm using the latest SVN build on karmic, but I tried going back to the latest stable version (december something). I tried different skins, cleaning the library, removing the HD movies source and adding it again.
If needed I'll tell you more about my system, and also provide some log files.
see details in my signature - more info needed for someone to help
Ok, here's some more info:
Running Karmic Koala 9.10 (2.6.31-17) and XBMC Pre-10.5 r27017 with Confluence skin. Hardware consist of Intel Core 2 Duo E7400 and GeForce 7100/nforce 630i.
So, looking through the logs I see the same error as reported by other ppl in here about VDPAU:
23:36:41 T:139838106052880 M:3044343808 NOTICE: Opening video stream: 0 source: 256
23:36:41 T:139838106052880 M:3044343808 NOTICE: Creating video codec with codec id: 28
23:36:41 T:139838106052880 M:3044343808 DEBUG: FactoryCodec - Video: - Opening
23:36:41 T:139838106052880 M:3044343808 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1280x720, 28)
23:36:41 T:139838106052880 M:3044073472 NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000001
23:36:41 T:139838106052880 M:3044073472 ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1. Falling back.
23:36:41 T:139838106052880 M:3044073472 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
23:36:41 T:139838106052880 M:3044073472 NOTICE: (VDPAU) Close
23:36:41 T:139838106052880 M:3044073472 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:36:41 T:139838106052880 M:3044073472 DEBUG: FactoryCodec - Video: ff-h264 - Opened
I tried upgrading my graphics driver, but using 190.xx or 195.xx gives me a "InstallArchives() failed".
iirc the 7100 does not support vdpau, needs to be 8x series or higher.
try changing your renderer to software.
also, post your full debug log there may be other relevant bits.
Well, that sucks (for me)
I did a full reinstall of the system, but it seems the problem still persist, even with software rendring. I will post a full debug log later.
Btw: Any recommendations for a different graphics card?
9400 is about the cheapest available i believe - have a search plenty of recommendations.
Seems like this is unsolvable.
A small update:
Yesterday I tried playing a 1080p movie with software rendering. It didn't go too well. My dual cores went through the roof. It was able to play, but it was very jerky. Mind you, this was started through the Files menu, not Library. So I thought I would give VDPAU another go, and presto, the stress on the CPU was reduced significantly. The playback was still not perfect, so I'll be buying a new graphic card soon. For 720p it works great though.
But, even 720p (no matter how great it works now) movies crashes when started from the Library. 720p TV Shows still work fine. It's so weird.
So, no one wants to touch this? No obvious errors in my logs?
Btw, I borrowed a 9400GT graphics card and pressing "o" now shows that VDPAU is active, and my CPU hardly does anything at all. Still, Library will freeze all playback.
I've almost found the answer. Here's what I've done:
- Removed my movies source, cleaned the library
- Moved a couple of 720p movies from my internal disk to my NSA
- Added the NSA disk as source and updated library
Library mode works again, so I'm wondering what actually caused this?
Is my internal disk going bad? - In that case, why did everything play through the Files menu?
Is there one movie causing havoc for the whole library? - I'm moving a few movies at a time over to the NSA and after each move I check if the library still works.
Should I've used another FS? - Right now the disk is NTFS because it was used in a Windows machine.
