2010-01-28, 18:24
Waffa Wrote:Pictures custom backgrounds is not working for home screen.Check SVN now as I've added a line that was missing from the code.
Waffa Wrote:Edit : Yeah it is id 25 sort by rating works fine now, thanks.Nice one, thanks
skunkm0nkee Wrote:Nice one! I never knew about the preloaditems tag at all so have gone through all the views that have images in the container (such as Wall Stream and Panel Stream) and have now updated the code to do background loading and pre-loading of images so hopefully that will run a bit smoother for you.
I don't have a usable version of XBMC here at the moment so I haven't tested any of these code changes but I'll be testing them over the next few days to make sure they work before making another release.
Thanks again for the feedback and if anyone has any other issues/suggestions please let me know and I'll see what I can do.
empty Wrote:An old ugly bug when you go back in a tv-series:
http://img193.imageshack.us/i/xbmc0003.jpg/
http://img189.imageshack.us/i/xbmc0004.jpg/
http://img18.imageshack.us/i/xbmc0005.jpg/
http://img43.imageshack.us/i/xbmc0006.jpg/
http://img96.imageshack.us/i/xbmc0007.jpg/
rob87 Wrote:looks very nice.
unfortunately the switch between the movies in media preview works not flawless like in the confluence skin.
skunkm0nkee Wrote:What version of XBMC and what platform are you running it on?
I use those views for TV and can't remember every seeing anything like that bug. Has anyone else seen something similar?
empty Wrote:In every version do you see this bug, i'm using linux,windows newest svn und this bug you can see when you select a serie und then switching back you see this for a very short (for me long) time. I could make a video if you want toNo need for a video, I'm just concerned that I haven't seen it. Will have to check it out properly tonight. Thanks for the feedback.
Quote:Not sure what you mean? Do you mean the smoothness when navigating a specific view for movies? If so then the code changes mentioned above should help when I release the next version.
MockY Wrote:So in versions later than MediaStream v1.60, it will become smoother to navigate through lists (whether it being movies, episodes, or shows)? There were a couple of post previously that mentioned jerkiness with the version they tried, but I'm not really sure if they mean the same as what I found. If it is, then you have my sincere apologies that I repeated it again.
What I instantly noticed was that scrolling through any type of list is very choppy, especially when I hit page down. The letter that used to smoothly appear, showing what letter you are currently on when you held down page down, does no longer appear and the picture is just skipping instead of smoothly scrolling.
I changed back to MediaStream 1.0 and it's smooth again. I am running Jauty Jakalope with XBMC 9.04 so that might have to with it? Or did the power requirements change (my current box is not a speed demon)?
