2010-01-27, 01:23
This should have been released a few days ago but I've been caught up with some ideas I'm working on for a new skin.
There's been a few changes since the release of v1.50 and a number of fixes too. The main changes are as follows:
You can download the skin at the following link - MediaStream v1.60
- Added: Fanart for music
- Added: the ability to show weather fanart (needs weather fanart images to be placed in the custom weather backgrounds folder)
- Added: ability to display weather fanart on Weather screen as well as Home screen
- Added: ability to display animated weather on home (requires animated weather images to be setup in an icons folder off of the custom weather backgrounds folder)
- Added: full screen versions of the Home screen backgrounds
- Updated: skin now uses a single multiimage for the backgrounds on the Home screen
- Updated: added year to Video OSD for episodes (was going to add air date but that's not available)
- Updated: tidied up the display on the File Manager screen
- Updated: tidied up transition from File Manager screen back to Home screen
- Updated: tidied up positioning of progress bars on scan dialogs
- Updated: Chinese (Simple) translations (thanks to taxigps)
- Updated: Spanish translation (thanks to nabz)
- Updated: Greek translation (thanks to ydatografida)
- Fixed: conditions for displaying the various parts of the video OSD
- Fixed: Don't display watched/unwatched overlay in List view or Info List view when viewing seasons data
- Fixed: made sure progress bar does not appear when full screen video is not being viewed
- Fixed: animations on Home screen
- Fixed: issues with options for weather on Home screen
- Removed: options to set a single custom background image for any of the screens (if you want a single image then place that image in a folder and set the folder)
- Removed: all the split images that used to be used for the default backgrounds
