2010-01-27, 09:41
Hi!
The other day I got myself a new projector (InFocus X10) and directly enabled auto refresh rate by editing my xorg.conf and setting the switch in xbmc. When playing movies, the projector source information shows me that I in deed have 24Hz and I see that also in the codec information.
I then played some test clips to check that I had in deed eliminated the 24Hz juddering, but it seems I haven't. When playing the opening scene in Transporter 2, where the camera rotates it judders so much I almost get sick. I turn off the auto refresh rate and I can't see any difference. As I have read tests on the projector before buying it, they say that one of the benefits with this model is that it is pretty good at displaying 24Hz material without judder. So I'm completely clueless here. I don't know what could be wrong and I don't know how I could debug it. Any ideas or information is VERY appreciated!
Edit: I could add that I use an Asrock ION 330 for htpc and my xbmc version is svn 26018. I also have a A/V receiver between the player and the projector (Marantz SR 6003), but I have this set as pass-through, so it shouldnt' do anything with the signal.
Maybe I should also add that before I used another projector with this xbmc setup. I'm starting to wonder if this could have messed things up. That I have old settings somewhere for my old projector. If I check my xorg.conf, the vsync/hsync are for instance not matching my new projector. But I know to little about this, so I don't know if it affects a certain resolution/frame rate-kombo or just sets the limits for what modes I could use. I mean, I DO get 1080p/24hz out, so it seems correct, right? Could I somehow get it to rebuilt the xorg.conf for my new projector or does it do that automatically?
Here is my current config:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Mon Mar 23 15:33:27 PST 2009
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "DynamicTwinView" "False"
Option "FlatPanelProperties" "Scaling = Native"
Option "NoLogo" "True"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
