Hi Guys,
Hopefully I am not the only one that finds this annoying.
When you are in Tri Panel for movies it shows you the number of films, but then it says items (20 Items).
Is there a way of changing that to movies or films (20 Movies 20 Films)
Regards
Mark
MarkTaunton Wrote:Hi Guys,
Regards
Mark
Edit
Xperience_List-Views.xml and at the bottom look for
PHP Code:
<label>$INFO[Container.NumItems] ITEMS</label>
change the label items so what you see fit.
Thanks a lot, looks a lot better having it like that.
Rocky5 Wrote:Edit Xperience_List-Views.xml and at the bottom look for
PHP Code:
Cool never thought of changeing that looks better now thanks
Just adding to this, I'm not sure if it would be possible but is there a way of when you are in a genre category such as say
Action
It can display something like 20 Action Movies or 20 Sci Fi Movies etc.
I think that it just makes it look tighter.
MarkTaunton Wrote:Just adding to this, I'm not sure if it would be possible but is there a way of when you are in a genre category such as say
Action
+1 for that idea
