Full Version: [WINDOWS] Xbox DVD Kit Dongle internal pinout help?
Hello everybody,
I'm new in XBMC world, and i guess i'm entering it the hard way !!
Just installed my HTPC last week with camelot 9.11 and it was a really great experience. I did also have an Harmony remote control, so i decided to use the dongle provided with the so called 'Xbox dvd playback kit"... And I opened it the wrong way.
As you can see 2 copper tracks are cut and not connected to pin holes anymore...
Can someone having the same kind of hardware can lead be to the correct setup ?
Is A connected to 1 and B connected to 2 (my opinion) ?
Or A & B connected to 1 (as normaly B is not needed to connect to usb cable) ?
Any help will be apreciate !! Thanks
