Full Version: .xbt based skin themes not implemented ?
i'm trying to create a few different themes for Transparency!, and while it works fine with .xpr files, it doesn't seem possible to do this with .xbt files.
none of the extra .xbt files show up in Settings > Appearance > Skin > Theme.
if anyone wants to have a look into it, you could test with Rapier, it comes with 4 different themes (both .xpr and .xbt).
just remove the .xpr files from the media folder and you'll notice you won't be able to select any theme anymore.
Probably just needs hooking up in the settings category. Will look into it.
Cheers,
Jonathan
r27233 may do the trick (untested, in the very best traditions)
it certainly does.
cheers jm.
