at startup xbmc suddenly starts a db slider countdown in the botom right hand corner, then after that it stays there and cant select options, anyone experienced that?
one of your controllers is either broken or semi-broken.
you'll need to change the deadzone value in xboxmediacenter.xml
thanx ur reply, ok but the controller is new, i will try another, not sure how to adjust that file tho...
