Hi Ronie,
is it possible to show the german rating icons in your skin.
I use OFDB and MovieMaze as scrapers and my movies were rated FSK0 FSK6 etc.
Is it possible to "enable" german icons
Thanks for your help and great work!!!
Oliver
i'ts been on my todo list for a while,
i'd better get it in right now before i forget it again. ;-)
done.
other languages on request!
What do you mean ...done
...f..cking fast!!!!!!!!!! Great!
Do I have to download the hole theme or is it possible to change some files??
you can download the svn version of Transparency! on google-code, instructions here:
http://xbmc.org/skins/transparency/5/
running the svn version of the skin also requires a recent xbmc svn.
svn: Kann Zeichenkette nicht von »UTF-8« in die eigene Codierung konvertieren:
svn: Transparency!/images/flags/movies/studio/Zesp?\195?\179?\197?\130 Filmowy Tor.png
maybe error in svn
Nope! And I know how to google, tried this first
run locale in the terminal and check the output.
it should list: LANG=de_DE.UTF-8
most likely you're using de_DE.ISO-8859-1 instead
So now I got everything ....
Newest XBMC-PVR + Transparency2.13-pre but German rating icons were not shown in libary mode(haveńt tested other view-modes yet)
Is there something left to do or am I just stupid?
just tried it myself and it works fine over here, though the icons look ugly...
i'll have to make some better ones.
could you bring up the movie info screen for one of your movies and post a screenshot?
Hi Ronie,
solved the prob by myself. In your include-file you wrote FSK12 but the german scrapers show FSK 12 so I modified all from FSKx to FSK x and everything works fine.
Concerning your icons youŕe right, theyŕe looking a little bit ugly.
I took the icons from an Aeon-Mod (colored).
liquidolze Wrote:Hi Ronie,
thanx, that's what i needed to know. :-)
i'll make those changes too.
liquidolze Wrote:Concerning your icons youŕe right, theyŕe looking a little bit ugly.
since all media flags are white, i thought i'd be best to convert the FSK flags to white too.
other than that, at the resolution the flags are being displayed, the 'freigegeben' text becomes completely unreadable.
Well I think the "freigegeben" Text isńt so important.
Maybe you could do icons only with "FSK ab 6"
After all I got another off topic question: Is it possible to hide the weather "display" on the top right side in the home screen?
Sorry for my wrotten english.
Regards
Oliver
P.S: threś another german rating called "FSK o.A." so I duplicated theFSK 0 part inthe file and changed it from FSK 0 to FSK o.A but took the same icon
