Full Version: XBMC 9.11 & Movie Trailers
While I do love the update with the new interface. I have been unable to figure out how to watch a trailer of a movie I have on my Drobo.
Usually when I play a movie I go to the folder, hold the play button, which brings up features like cast, play, refresh, get thumb, and get fanart.
But no where on this screen does it give me the option to watch the trailer.
I used to do this on XBMC, was this feature removed?
Hi there
I think it depends on the skin you're using, in Confluence pressing information should show it as an option on the right hand side BUT! in order for this to work the trailer has to be called moviename-trailer.ext
so if you had
Back to the future.mkv
the trailer would be called
back to the future-trailer.mkv
Can you confirm what the filename(s) are and what skin you're using?
Cheers
