Full Version: XBMC plays vdr recordings (TS) fine, but.. (HD/SD/crystalhd)
i am playing transportstream files for months without any problem. works like a charm. today i installed my crystalhd and whoops, just awesome to see hd movies play on that appletv box.
so i wanted to try my vdr hd recordings. i shutters alot, does anyone has an idea what that is? or anyone has succeeded playing that?
here is the ffmpeg -i output
Seems stream 0 codec frame rate differs from container frame rate: 100.00 (100/1) -> 50.00 (50/1)
Input #0, mpegts, from 'movie/2010-01-29.16.47.29-0.rec/00001.ts':
  Duration: 00:00:55.21, start: 1586.198278, bitrate: 11612 kb/s
  Program 132
    Stream #0.0[0x780]: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50 tbr, 90k tbn, 100 tbc
    Stream #0.1[0x781](deu): Audio: mp2, 48000 Hz, 2 channels, s16, 192 kb/s
    Stream #0.2[0x782](eng): Audio: mp2, 48000 Hz, 2 channels, s16, 192 kb/s
    Stream #0.3[0x783](deu): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
thanks for any help. i can provide a sample if someone likes to test.
-andy
sample: https://overlord.fh-salzburg.ac.at/~asar...mc/sample/
this is my xbmc version:
Starting XBMC, Platform: Mac OS X. Built on Jan 29 2010 (SVN:27265)
I think you need as a minimum an output of mediainfo otherwise here you dont even get started
how to get that? i thought the ffmpeg output is enough.
-andy
download media info and put some more info on the file
General
Complete name                    : 00001.ts
Format                           : MPEG-TS
File size                        : 76.4 MiB
Duration                         : 54s 0ms
Overall bit rate                 : 11.9 Mbps
Video
Menu ID                          : 132 (0x84)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Duration                         : 54s 0ms
Bit rate                         : 10.2 Mbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Display aspect ratio             : 16:9
Frame rate                       : 50.000 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.222
Stream size                      : 65.8 MiB (86%)
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 2
Duration                         : 53s 760ms
Bit rate mode                    : Constant
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 48.0 KHz
Stream size                      : 1.23 MiB (2%)
Language                         : German
Language, more info              : Clean effects
Audio #2
Format                           : MPEG Audio
Bit rate                         : 192 Kbps
Language                         : English
Audio #3
Format                           : AC-3
Format/Info                      : Audio Coding 3
Duration                         : 53s 952ms
Bit rate                         : 448 Kbps
Channel positions                : L R
Stream size                      : 2.88 MiB (4%)
Language                         : German
added sample in top post
Frame rate 50 fps seems a hell of lot
its a "normal" television recording. video is 10-12 mbit
I don't think the whole set work with interlaced sources
