2010-01-29, 23:23
2010-01-29, 23:27
depends on your skin
you need to enable "library mode" go into movies or videos..whatever it's called..and its usually something like left or right on the dpad to slide in the sidebar and enable library mode..
like i said depends on the skin
also you have to add the content to thee library by going in file view mode, highlight the folder the video is in then hit the clear button for context mennu and "set content"
