Well last eden builds have changes on their json implementation.
I'll soon release a new build that handle Eden builds.
But since i forgot to update the https certificate and did not release update before this to disable https updates. Next update will need to be done manually, Yatse won't auto detect it.
For users wanting xbmc to auto change audio output, it's not actually possible to do this remotely.
Please open a trac ticket on xbmc to ask for such a feature.
Well finally not so much changes
Build 130 online.
Please don't forget you need to manually update as the updater in pre 130 builds is broken due to https certificate.
And please edit your remote to change the plugin to XBMC - Eden.
Hi Tolriq,
Great software you have here.
It ends up being the perfect partner for my Fingervu 1016W and I just wanted to know if you had any schedule for future developments such as:
- Web Radios
- Playlists handling
- Party mode
-A plug-in to connect to sites like Grooveshark would also be much appreciated.
Thanks,
Ds
dsforum Wrote:Hi Tolriq,
- Web Radios
- Party mode
Thanks,
Ds
I'd love to see this also.
I have used my TS case with another HTPC app and custom designed scripts to make some use of it. Now I have discovered XBMC as a great replacement this looks like it could really bring it to life.
If it works as I hope i'll be looking at donating some money for this. Brilliant work
I had such problem. I try to operate from the laptop live image, at me all is connected but management isn't present that it is possible to make in the present state of affairs
For the moment dev of new feature is halted, i'll only maintain support for new xmbc release if they happens as i did for the last beta of eden.
I'll keep you in touch when i'll go back on this (well when i got more personal time :p )
Tolriq Wrote:(well when i got more personal time :p )
I can understand this... I have a new baby boy (in addition to my other 2yo) and I just started trying to setup a new media center system at home so i'm squeezing in what I can where I can.
Cheers for your effort so far though, it's absolutely brilliant and i'm amazed people can come up with solutions like this (why cant companies like iMon do it)
Hello,
I've got the ZALMAN HD160XT Plus with the IMON Touch Screen. I also have XBMC Dharma in the same PC running over Windows XP. I've installed YATSE but have not been able yet to "Add Remote" (which I believe it's necessary in order to populate the library). Can someone give me a hint regarding the configuration parameters ? Also, typically, how much time takes to populate the library assuming that you may have lots of stuff upon XBMC (it's just that the one time I didn't get an error, some hours have past and I didn't figure out what the application was doing) ?
Best Regards.
Thanks Tolriq,
That was very useful information. I'm now on the process of populate the library.
Regards.
Hi Tolriq,
I haven't been able to populate the Audio section of YATSE. I've got several albums available at XBMC, properly tagged using MediaMonkey. On Artists only appears "V" for "Various Artists" and the information are empty. On Albums, I'm asked to update the library.
The Video section is working fine.
Do you have any hint ?
Best regards.
I seem to be having a couple of issues with this.
Im on winXP using 22 Aug Build
Testing this on my dev machine I notice that with XBMC fullscreen when I touch the Yatse screen, XBMC is minimized. How do people prevent this from happening (and I don't want to run in windowed mode).
Secondly, I have no Video thumbs at all. Music is all fine but the video cache folder in Yatse is empty and nothing is displayed on the screen.
Any ideas?
EDIT: Had some time to research the fullscreen issue but still stuck with the images for TV shows not showing
For your library problems please open cases in yatse web site with an upload of the log in the log subdir. (Preferably in debug and trace mode see wiki on how to activate them).
Hello phsyraxion,
You seem to have with Video what I was experiencing with Audio. My problem was that my XBMC Music was not in "Library Mode". Once I switched to "Library Mode" and updated upon YATSE it was fixed.
Best regards,
