I'm waiting for months already.... Please give HTPC touchscreen owners their screen back.
This is the only fine piece of software I can find. If you update I'll make a donation!
I hope you'll find some time soon. Thanks 4 all you have done already.
I'll try don't worry but to be honest at the moment on my both project 100% of the people who have said do that I'll donate did not
So this is not really the motivation tool
(2013-01-21, 22:50)Tolriq Wrote: [ -> ]And ?
Any suggestions to solve it?!
So perhaps avoid stupid message that will piss the dev off ?
I'm quite patient but such message ......
(2013-01-21, 23:10)Tolriq Wrote: [ -> ]So perhaps avoid stupid message that will piss the dev off ?
Actually i dono what exactly did "piss you off" but iam very sorry for that!
Just trying to find help for my problem. Nothing more nothing less...
Iam out.
(2013-01-21, 22:48)o0oFoXo0o Wrote: [ -> ] (2012-10-08, 23:46)o0oFoXo0o Wrote: [ -> ]Hallo.
I recognize a strange problem with yatse2 while playback.
After starting yatse its updating/downloading thumbnails and fanart. Now i start a movie/tv-show while yatse is still downloading
thumbnails/fanart. Display shows the information screen like it should. After a short time the display shows "done downloading thumbnails/fanart"
but returns to the mainscreen of yatse WHILE playback! If i start a playback AFTER the "done downloading" message everything works perfekt.
Iam using YATSE2 with XBMC Eden on a Silverstone SST-GD02S-MT with 4.3" TFT touch-screen display, Windows 7 Home Premium 64Bit.
Thankful for your help.
Problem not solved ...
If you don't know the problem in this post well I can't do anything for you
(2013-01-21, 23:27)Tolriq Wrote: [ -> ] (2013-01-21, 22:48)o0oFoXo0o Wrote: [ -> ] (2012-10-08, 23:46)o0oFoXo0o Wrote: [ -> ]Hallo.
Your are absolute right! Maybe next time i should not write "Problem not solved".
I appreciate that.
(2013-01-21, 22:40)Tolriq Wrote: [ -> ]I'll try don't worry but to be honest at the moment on my both project 100% of the people who have said do that I'll donate did not
I just donated 5 euros in advance, hope to use your program in the future!
Good luck and keep us updated.
Greets,
David
Thanks for that but as I said this is more a time problem than anything else
I've said I'll do it so it will be done just needs time.
I'll try to push to github each time I do a little part even if the plugin is not finished so you can see if it is advancing or not
Hey Tolriq, super application, ça a vraiment un beau look!
Question: is it possible to use Yatse2 with no mouse and no touchscreen?
I would have tought it would be possible to use the keyboard's left/right and Enter to navigate trough the menu in order to queue music, but I haven't found any keys that works...
No
All is written for mouse / touchscreen.
