2015-07-02, 05:30
Here you go, I hope it helps you find out what's wrong...
Yatse2.log
Yatse2.log
(2015-07-02, 05:11)GlennNZ Wrote: [ -> ](2015-07-02, 04:54)MKANET Wrote: [ -> ]Reverting back to the old Yatse2 makes music fanart work again using the same settings in my XML config file. Kodi on my setup hasn't changed (plugin/addon-wise).
I agree, it DOES depend on my Kodi setup. However, nothing really changed there to change music fanart behavior (at least nothing obvious). It still displays the same in Kodi for the same albums and songs as before.
So, I also need to install the yatse2.service just to get music fanart to display in PlayNow? Any way to just get it to work more like before (without the need for depending on the service).
EDIT: This happens on ALL music... not just local music files; but, streaming too (like the Google Music addon).
PS: If you still need a log file, what do I need to do exactly to get you the information you need?
Log file - enable debug and trace in settings screen. Restart Yatse, log located in %appdata%\Yatse 3 Socket\Logs. Copy and paste log to pastebin.com and paste link.
re: Yatse2.service - shouldn't need to have service installed for music fanart - but may be how it is coded currently. Will check and update if easy fix (which should be) - But do need log to have a look at paths which is probably where the problem lies.
Glenn
