(2015-07-12, 04:01)MKANET Wrote: [ -> ]Hi Glenn,
Ok....Where to start... (Please have a look at the below a few times as believe we have been covering same ground a couple of times)
Thanks for the zip file logs.
Basic Problem is that - Your Directory structure is completely wrong (but easily fixable) as per this past post
http://forum.kodi.tv/showthread.php?tid=...pid2043463
1. Fix Default Paths
MKANET Wrote:<FanartDirectoryMusic>D:\Multimedia Files\CD-Artwork\</FanartDirectoryMusic>
No this is incorrect -- Cannot be there.
Quote:
Default Directories if No Fanart in extrafanart folder (or if not using yatse2.service)
Defaults to artworker organizer defaults (to use these need to have artwork organiser addon added and run)
They must be within or created in %appdata%\Kodi\userdata\
eg.
Fullpath is %appdata%\Kodi\userdata\addon_data\script.artworkorganizer\ArtistFanart\
or on your install
C:\Users\MKANET\AppData\Roaming\Kodi\userdata\addon_data\script.artworkorganizer\ArtistFanart\
The above are the
DEFAULT - used if no extrafanart directories only. Should be a pile of images with no folders - when there is no artist specific fanart this is used.
ALSO: as per instructions (see pdf on github)
http://kodi.wiki/view/Add-on:Artwork_Organizer
<FanartDirectoryTV>addon_data\script.artworkorganizer\TVShowFanart\</FanartDirectoryTV>
<FanartDirectoryMovie>addon_data\script.artworkorganizer\MovieFanart\</FanartDirectoryMovie>
<FanartDirectoryWeather>addon_data\skin.aeonmq5.extrapack\backgrounds_weather\</FanartDirectoryWeather>
<FanartDirectoryMusic>addon_data\script.artworkorganizer\ArtistFanart\</FanartDirectoryMusic>
<FanartDirectoryMyImages>addon_data\script.artworkorganizer\OwnFanart\</FanartDirectoryMyImages>
(on your setup from the log Yatse is looking here:
C:\Users\MKANET\AppData\Roaming\Kodi\userdata\"D:\Multimedia Files\CD-Artwork\" clearly this doesn't exisit)
Need to fix this would suggest use artwork.organiser defaults as above and run artwork organizer
2. Move Artist/extrafanart directories to KodiMusicRoot
The Extrafanart folder is the only one used, other than cdart.png for local albums.
As mentioned a few times with your CdArtManager issues - the extrafanart directory needs to be
(see this post
http://forum.kodi.tv/showthread.php?tid=...pid2043463)
:Kodi MUSIC Source
----/ArtistName Folder
----------/extrafanart/
---------------Images, Images, Images, Images (these are the ones used - if exist)
This is the default for CdArtManager when select download fanart all artists, which will download, create and fill all these extrafanarts.
From the log this is for your install
D:\Multimedia Files\Music\ARTISTNAME\extrafanart\ <--- artist images go herel, all of them...
For example you play Rev Theory song from googlemusic during the log. It tries to find artwork here:
"D:\Multimedia Files\Music\Rev Theory\extrafanart\"
This directory is checked for fanart images - none are found, so default used.
& later
no images in D:\Multimedia Files\Music\Rodney O\extrafanart\
etc.etc.
So:
Copy you Cd-Artwork tree to the Kodi Music Source folder which is D:\Multimedia Files\Music\ (will use the extrafanart folders)
3.Connection:
Actually the connection seems fine.
Connection - does connect and does send socket info without any problems in the Yatse log
Kodi shows one failure connection - but I believe Yatse was closed.
Finally - if not otherwise --
4. Music Fanart Rotation needs to be OFF (I should really disable it as can't see point)
So:
1. Hopefully can sort out path tree - only the extrafanart directory will be used - so welcome to copy all the relevant artist fanart there.
Then:
2. Default paths need to be changed in the xml (as above). These are for a collection of fanart from every artist, or every tvshow or every movie in your library (which is used when no fanart for any of these categories)
Again these are the defaults for artwork.organiser.
http://kodi.wiki/view/Add-on:Artwork_Organizer - install and run and will populate these fanart directories for you.
I would change the xml back to the defaults - and use artwork organizer to fill. Need to be within %appdata%/Kodi/userdata/ if using another directory of your choosing
3. Make sure music fanart rotation is off..
for more see the now updated pdf instructions
https://github.com/Ghawken/Yatse2-1/rele...ctions.pdf
