XBMC keeps crashing after i select my source and set contents it will set the contents but once i go to videos the app quits with the following error "The application XBMC quit unexpectedly" it will also do that if i just press escape on the keyboard can someone please help me? i am running the app on a fresh install 10.5.8 PowerPC G5 Quad 2.4 with 4g memory
magster Wrote:XBMC keeps crashing after i select my source and set contents it will set the contents but once i go to videos the app quits with the following error "The application XBMC quit unexpectedly" it will also do that if i just press escape on the keyboard can someone please help me? i am running the app on a fresh install 10.5.8 PowerPC G5 Quad 2.4 with 4g memory
xbmc.log and crashreporter.log files please.
http://www.pastebin.com them.
were are those files located?
magster Wrote:were are those files located?
see my sig. those are for the AppleTV so replace "frontrow" with your user name.
I´ve got the very same problem. XBMC works maybe 1 out of 10 times without crashing. My audio stops working completely and requires a reboot to work again, for any aplication.
Skalman Wrote:I´ve got the very same problem. XBMC works maybe 1 out of 10 times without crashing. My audio stops working completely and requires a reboot to work again, for any aplication.
xbmc.log? crashreporter.log?
Posted to Pastebin.com.
Post Skalman
Thanks for all your help.
