2010-01-30, 14:25
I have installed the BBC IPlayer plugin and would like to add a "shortcut" to launch this straight from Confluence Homescreen. I have added the following entry in the Home.xml file
<item id="13">
<label>IPlayer</label>
<onclick>xbmc.RunPlugin(plugin://video/iPlayer)</onclick>
<icon>special://skin/backgrounds/settings.jpg</icon>
<thumb>$INFO[Skin.String(Home_Custom_Back_Settings_Folder)]</thumb>
</item>
However, when I click on the entry nothing happens and I get
12:17:31 T:6448 M:173821952 ERROR: DIRECTORY::CPluginDirectory::AddSortMethod - called with an invalid handle.
12:17:31 T:6448 M:175943680 ERROR: DIRECTORY::CPluginDirectory::AddItem - called with an invalid handle.
In the logfile. Plugin works OK when I launch it from "plugins"
Would appreciate some assistance with this or a heads up if this is not related to Confluence and I should post in the forum for the plugin instead.
Many thanks!
<item id="13">
</item>
Many thanks!
