2010-01-31, 04:17
I'm migrating from the good old xbox and am playing with Live on a Revo1600. It seems to work fantastic. I just have a couple of questions about keymapping.
I've read the Wiki and I've done a fair amount of keymapping for my orginal xbox but it looks like the structure has changed.
What I want to do is
1) Change a couple of remote functions. From what I can tell I can just put these in a remote.xml and drop it in my userdata/keymaps folder.
ex to change green button from myvideos to parent directory. I should create a remote.xml with
<keymap>
<global>
<remote>
<green>ParentDir</green>
</remote>
</global>
</keymap>
and place it in my userdata/keymaps folder. Correct? I don't have to do anything with the system keymap and I don't need the unchanged part of the keymap.
2) Is there a command for suspend. Right now I can suspend and resume fine using the shutdown menu but I'd like to map the power button to suspend/resume instead of off. I checked the wiki but couldn't find it.
M
<keymap>
<global>
<remote>
</remote>
</global>
</keymap>
M
