I just created
a ticket for this bug and thought I should cross-post it here. Has anyone else noticed this?
I'm using the latest SVN nightly r27311. I've noticed that selecting Reboot in the Shutdown Menu now works the same as selecting Shutdown or Exit: you are taken directly to the AppleTV Frontrow main menu. Previously, in earlier nightlies and in 9.11 Final, selecting Reboot correctly caused AppleTV to power cycle.
The only way to power cycle the AppleTV after updating to the latest nightly is to ssh in and sudo reboot or pull the plug. Rebooting is necessary to get XBMC to recognize CrystalHD after updating.
Y'know, I saw Launcher 3.2.3pre-r740 listed in the Launcher --> Downloads, but as I wasn't sure what changed, I was afraid to update!
Unfortunately, after installation, XBMC loads up fine, but selecting Reboot in the Shutdown Menu still brings you directly to the AppleTV Frontrow main menu, just like selecting Shutdown does. Still no power cycle.
Mind posting console.log? (if it doesn't update properly kill finder via ps aux |*grep Finder .... kill <PID> and it should start working again)
I'm sorry, there's no console.log in /mnt/Scratch/Users/frontrow/Library/Logs. If you give me a "For Dummies" explanation on what to do using Putty, I'll be happy to post it! Numbered steps are awesome...
In case it helps, here is the xbmc.log, with me starting XBMC, bringing up the Shutdown Menu and selecting Reboot:
http://pastebin.com/m19f62668
console.log can be found here: /Library/Logs/Console/501/console.log
I'm sorry, I made a mistake, I meant to say that there is no Console folder in /mnt/Scratch/Users/frontrow/Library/Logs. The only contents of that folder (according to WinSCP) is a CrashReporter folder (which contains CrashReporter.log) and two files: xbmc.log and xbmc.old.log. It appears that Launcher did update okay, as the version in the Launcher --> About section is "Launcher 3.2.3pre-r740".
try
Quote:/Library/Logs/Console/501/
instead of
mind retrying with a version >= r27320? Just seen there was a
bug fix
I just installed the latest nightly (r27349) and Reboot still acts like Shutdown.
I finally found console.log here:
/mnt/Scratch/Library/Logs/Console/501
I got confused because WinSCP automatically starts in /mnt/Scratch/Users/frontrow and there is a Library folder with a Log folder inside of it there!
I rebooted AppleTV (with PuTTY), started XBMC through Launcher and then chose Reboot in the Shutdown Menu. Here is the console.log:
http://pastebin.com/m52abb3b9
Hi KevinSartori,
thanks for the log.
KevinSartori Wrote:I just installed the latest nightly (r27349) and Reboot still acts like Shutdown.
You're saying that Reboot shuts down the ATV or it does (like Shutdown) nothing?
In XBMC, Shutdown, Reboot and Exit all seem to do the same thing: bring you directly to the AppleTV Frontrow menu. With earlier builds (including 9.11) selecting Reboot used to actually power cycle the AppleTV (like pulling the plug) before bringing you to the AppleTV Frontrow menu.
I have the Broadcom CrystalHD card and when I update to the latest SVN nightly, you have to power cycle (Reboot) the AppleTV to get XBMC to recognize the Broadcom CrystalHD card. With Reboot not working properly in XBMC's Shutdown Menu, I have to either ssh in and sudo reboot or pull the plug to get the AppleTV to power cycle (Reboot).
KevinSartori Wrote:I have the Broadcom CrystalHD card and when I update to the latest SVN nightly, you have to power cycle (Reboot) the AppleTV to get XBMC to recognize the Broadcom CrystalHD card.
I am facing the same problem concerning the reboot entry, I reboot through the Software Menu/Scripts Reboot entry instead.
Bobby Blixberg Wrote:I am facing the same problem concerning the reboot entry, I reboot through the Software Menu/Scripts Reboot entry instead.
Launcher version and console.log please
Launcher 3.2.2
My /Library/Logs/Console/501/console.log is from 22.01.2010, so is it of any use in this case...:confused2:
Here's the content anyway:
Apple TV OS Version 10.4.7 (Build 8N5983)
2010-01-22 17:54:37 +0100
2010-01-22 17:54:41.062 Finder[226] settings facade <ATVSettingsFacade: 0x190c610>
Jan 22 17:54:41 AppleTV /System/Library/PrivateFrameworks/AppleTV.framework/Resources/SettingsHelper: Request to change power settings: 0
Jan 22 17:54:41 AppleTV /System/Library/PrivateFrameworks/AppleTV.framework/Resources/SettingsHelper: WDOG: reset boot count to zero
Jan 22 17:54:54 AppleTV FrontRow[226]: AP: failed to find any interfaces (null): -4
Jan 22 17:54:54 AppleTV FrontRow[226]: AP: failed to open connection to check for power: -4
<CGColor 0x1936760>
2010-01-22 17:54:55.541 Finder[226] success loading AppleShareClient
2010-01-22 17:54:55.775 Finder[226] success loading DVDPlayback.framework
2010-01-22 17:54:56.847 Finder[226] a
2010-01-22 17:54:56.901 Finder[226] [DEBUG] +[XBMCAppliance initialize]
2010-01-22 17:54:56.903 Finder[226] [INFO] Launcher running in pure mode
2010-01-22 17:54:57.089 Finder[226] [DEBUG] +[XBMCAppliance className] called for whitelist check, so I'm lying, m'kay?
2010-01-22 17:54:57.295 Finder[226] SMVersion In package: 5
2010-01-22 17:55:01.438 Finder[226] [DEBUG] -[XBMCAppliance previewControlForIdentifier:]
2010-01-22 17:55:04.028 Finder[226] [DEBUG] -[XBMCAppliance controllerForIdentifier:args:]
2010-01-22 17:55:04.029 Finder[226] [DEBUG] -[XBMCPreferencesController init]
2010-01-22 17:55:04.032 Finder[226] [DEBUG] -[XBMCPreferencesController recreateMenuList]
2010-01-22 17:55:04.090 Finder[226] [DEBUG] +[XBMCPreferencesController autoUpdateEnabled]
127.0.0.1 mesu.apple.com
2010-01-22 17:55:04.122 Finder[226] [DEBUG] +[XBMCPreferencesController autoUpdateEnabled]
2010-01-22 17:55:04.123 Finder[226] [DEBUG] -[XBMCPreferencesController recreateAppList]
2010-01-22 17:55:05.942 Finder[226] [DEBUG] -[XBMCPreferencesController dealloc]
Jan 22 17:59:19 AppleTV /sbin/kextload: can't create file /System/Library/Extensions.kextcache: Cross-device link
Jan 22 18:11:03 AppleTV reboot: rebooted by root
