2010-02-01, 07:16
Hi all.
I experiment the hardware decoder Broadcom CrystalHD 70012 on the motherboard of Intel D945GSEJT.
For check of operation of the decoder I wish to instal xbmc from svn.
I use Gentoo linux, here the information on my system.
Installation xbmc-9999.ebuild is completed with an error.
Fmpeg svn, revision 21578 is installed.
Xbmc-9999.ebuild try to instal xbmc svn, revision 27347.
At installation xbmc-9999.ebuild, a script ./configure It is started with parametres:
--prefix=/usr --build=i686-pc-linux-gnu --host=i686-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --disable-ccache --disable-optimizations --enable-external-libraries --enable-goom --disable-avahi --disable-dvdcss --disable-debug --enable-faac --disable-joystick --disable-mid --enable-gl --disable-profiling --disable-pulse --disable-vdpau --disable-xrandr
