2010-08-18, 01:26
2010-08-18, 01:30
davilla Wrote:To quote "There is also the new bcm70015 Crystal HD cards and these are also supported with this driver/lib/firmware provided you build from svn trunk. A release version has not been made the includes bmc70015 support yet."
You MUST compile from source code for bcm70015 support.
And from the download page "crystalhd kext, library and firmware based on r26" for crystalhd-for-osx-1.0.3.zip.
You're not paying attention to what is written
I'm trying to pay attention -- honest!
I could swear that I read that a driver was compiled and released by Andy(?) which would save us from having to compile our own bcm70015 source code.
Maybe it was wishful thinking. :confused2:
2010-08-18, 01:32
dregray Wrote:ok im in xcode and i downloaded the drivers now i need to get them into xcode how do i do that
ah, follow the guide at http://code.google.com/p/crystalhd-for-osx/
and before you ask, you will need to check out the source code (I don't know what you mean by "downloaded the drivers"). There's only one driver, one library and two sets of firmware, one for bcm70012, one for bcm70015.
http://code.google.com/p/crystalhd-for-o...e/checkout
2010-08-18, 01:35
Scott B Wrote:I'm trying to pay attention -- honest!
Andy is on vacation right now He takes care of the updating driver/lib/firmware in Launcher downloads. I've asked him to hold off doing this until I got more feedback.
Andy did release a previous manual install version but it's not current anymore.
2010-08-18, 01:41
davilla Wrote:Andy is on vacation right now He takes care of the updating driver/lib/firmware in Launcher downloads. I've asked him to hold off doing this until I got more feedback.
So I'm not just making things up -- good to know.
Does "not current" mean "won't work for me?"
My bcm70015 card arrives Thurs and I'm hoping that it won't just sit there dreaming of decoding 1080p for weeks.
2010-08-18, 01:48
Scott B Wrote:So I'm not just making things up -- good to know.
Current means it's not based off r145 (http://code.google.com/p/crystalhd-for-osx/source/list), that is current.
2010-08-18, 01:53
Brow beat me into submission.
http://code.google.com/p/crystalhd-for-o...loads/list
crystalhd kext, library and firmware based on r145 -> crystalhd-for-osx-2.0.0.zip
Now I have to tag and blah, blah, blah,
2010-08-18, 02:04
davilla Wrote:Brow beat me into submission.
Awesome!!! Thank you.
2010-08-18, 02:22
cool is there a screen shot of what it should look like in xcode the other link to view didnt work
2010-08-18, 02:42
@scott B - if still interested in building your own code..I was in your position not too long ago and all the info you need is here in this forum, up on the crystalhd-for-osx google code site and through your friendly search engine. It took me awhile to figure out where things were, how to install them and use them, but I just gritted my teeth and kept digging until I figured it out. I just felt it was better to do it this way as I'd much rather have davilla working on code for my AppleTV.
Here's some links to get you started:
CrystalHD - http://code.google.com/p/crystalhd-for-osx/
MacPorts - http://code.google.com/p/xbmc-port-depends/
Xcode - http://developer.apple.com/tools/download
And if building XBMC from svn, it also helps to look at the README.osx from the trac, an example: http://trac.xbmc.org/browser/trunk/README.osx?rev=32869.
@dregray - translation for you: if still building ur own code..i was same position long ago all info here in forum on crystalhd-for-osx google code site through search it took me awhile to figure out where things how to install use but i gritted teeth digging figured out i just felt better id much rather have davilla working on codeheres links to httpcodegooglecompcrystalhdforosx httpcodegooglecompxbmcportdepends httpdeveloperapplecomtoolsdownload if building xbmc helps to look at the readmeosx httptracxbmcorgbrowsertrunkreadmeosxrev32869
2010-08-19, 06:18
In my fumbling around I just tried to use the installer in the OP. I figured it might fix whatever is wrong and that I could just update the driver/firmware/lib afterward.
R26 downloads and then says "An Error Occurred."
2010-08-19, 06:29
Scott B Wrote:In my fumbling around I just tried to use the installer in the OP. I figured it might fix whatever is wrong and that I could just update the driver/firmware/lib afterward.
Turbo's web site is down, Launcher does a chained download that includes turbo_atv_enabler.bin and that's failing.
2010-08-21, 07:27
davilla Wrote:Turbo's web site is down, Launcher does a chained download that includes turbo_atv_enabler.bin and that's failing.
I am a noob but is the installer going to error out until turbo's site is back up? Is there a workaround?
2010-08-21, 07:38
nodrugads Wrote:I am a noob but is the installer going to error out until turbo's site is back up? Is there a workaround?
Yes. Until a) his site comes back up or b) the script is changed, it will error out. The workaround is to install manually. Several users have already written guides to install manually.
2010-08-25, 09:50
i am back from the holidays and currently sorting some pictures i hopei can push out an updated version of the installed until this evening or tomorrow morning.
-andy
-andy
