2010-10-26, 22:12
2010-10-26, 22:21
2010-10-26, 22:39
thx andy204 for churning this. guibaa and nmrs, make sure you are setup to use the R172 driver/lib before replacing the driver as driver/lib are pared.
2010-10-26, 22:48
thanks for the info. i forgot to mentions this. in the driver.tar.gz is just the driver kext. so you need to install the r172 via launcher first.
if it doesnt work and you install r156 via launcher again, you will have a working version again.
2010-10-26, 22:53
andy204 Wrote:guibaa and nmrs, try this please:
-andy
Hi scott and andi,
sorry for delay, that's is it now it's working fine, great job
guibaa
2010-10-26, 23:00
as soon scott releases a new revision i will update the launcher installation. that will be tomorrow, now its bed time
edit: i will delete the driver.tar.gz file and the instructions. i dont want others to do the same...
good night
-andy
good night
-andy
2010-10-26, 23:15
andy204 Wrote:as soon scott releases a new revision i will update the launcher installation. that will be tomorrow, now its bed time
good night
-andy
HEHE, not done yet This just points me in the right direction. I have another change but I need to test it first before letting it out.
EDIT: R174 with power handling for osx turned off.
2010-10-27, 03:50
davilla Wrote:As the other guys have said, the whole system is slow as soon as XBMC iis launched, the RSS scroll is just a sympton. And yes, Beta 2 as I specified in my original post.cray- Wrote:Same problems for me I'm afraid. Brand new BCM700015, loaded up Dharma Beta 2 & r156 in aTV as soon as I installed the card. Everything worked great.CrystalHD has nothing to do with "RSS feeds scrolling along the bottom of the screen". Also you are running beta2 and your log shows;
Tonight I ran the r172 update and lost the CrystalHD option in settings. Everything in XBMC was chugging, even the RSS feeds scrolling along the bottom of the screen.
I also managed to launch XBMC, play an SD file (badly) then quit back out to the aTV Finder before crashing the system.
davilla Wrote:I will reload r172 (if the launcher script still allows) and try to get you dmesg output. Last night my wife was eager to watch some new shows so I didn't have time to stuff around. We almost need a 2nd aTV to use as a test machine before rolling out changes to the lounge room.Quote:20:59:05 T:2684407808 M: 21434368 DEBUG: SECTION:LoadDLL(libcrystalhd.dylib)Which means crystalhd open failed and you are using ffmpeg software decode. I want to see the output of dmesg after XBMC launches.
20:59:05 T:2684407808 M: 21401600 DEBUG: Loading: libcrystalhd.dylib
20:59:09 T:2684407808 M: 38776832 DEBUG: CrystalHD: device open failed , returning(0xffffffff)
20:59:09 T:2684407808 M: 38776832 DEBUG: CrystalHD: broadcom crystal hd not found
2010-10-27, 08:52
released CrystalHD r174 (20101027)
changed: "disabled power handling"
http://code.google.com/p/crystalhd-for-o...tail?r=173
-andy
-andy
2010-10-27, 17:45
Anyone care to explain what this means? What exactly is the feature being disabled? I'm just curious.
2010-10-27, 18:11
davidhildreth Wrote:Anyone care to explain what this means? What exactly is the feature being disabled? I'm just curious.
eh ? did you actually look at the commit ?
2010-10-27, 19:24
CrystalHD r174 works great!
Thanks alot davilla and andy204 for all your help!
2010-10-27, 19:38
davilla Wrote:eh ? did you actually look at the commit ?
I was looking for someone to explain what "power handling" is and what it does. It's just a curiosity.
2010-10-27, 20:17
suspend / resume
2010-10-27, 20:58
Ah, thanks.
