Will this run if I have used ATV Flash.
Sorry for the Noob question here.
If someone can point me in the right direction for using crystal HD and XBMC with ATV Flash
Thank You
pudljmpr Wrote:Will this run if I have used ATV Flash.
Thank You
Sorry, as author of atv-bootloader which ATV Flash uses, I dislike supporting any patchstick derivation that does not return anything to the community. Your best option is to ask on the ATV Flash forums, after all you did pay them money for ATV Flash and that included support.
davilla Wrote:Sorry, as author of atv-bootloader which ATV Flash uses, I dislike supporting any patchstick derivation that does not return anything to the community. Your best option is to ask on the ATV Flash forums, after all you did pay them money for ATV Flash and that included support.
Actually I have not purchased it yet.
As a total NooB to atv I thought that might be the easiest way to get this up and running, I may have been wrong.
I will reread all of the good stuff you have here and try it.
Guys, how the installer sets crystalhd kext to load at boot?
Long time ago I did manual installation which used /etc/rc.local, but two weeks later I reinstalled everything and went with Launcher and this script and now I see that rc.local is not used..
Not that the install isn't working, I just want to know where and how kext is loaded
nikiiv Wrote:Guys, how the installer sets crystalhd kext to load at boot?
the standard osx way using launchd
davilla Wrote:the standard osx way using launchd
That would be /System/Library/StatupItems and plist distributed in the tar.gz file, right?
Nice.. thanks
I am a Linux user and it is always nice to learn something new about other Unix systems
nikiiv Wrote:That would be /System/Library/StatupItems and plist distributed in the tar.gz file, right?
Nice.. thanks
in this folder you find the startup files:
/System/Library/StartupItems/LoadCrystalHD/
this files get installed. / as root where files are extracted.
-bash-3.2$ tar tvfz crystalhd.tar.gz
drwxr-xr-x root/wheel 0 2010-01-31 09:50:07 System/
drwxr-xr-x root/wheel 0 2010-02-14 21:52:00 System/Library/
drwxr-xr-x root/wheel 0 2010-01-31 09:50:29 System/Library/Extensions/
drwxr-xr-x root/wheel 0 2010-02-14 21:52:23 System/Library/StartupItems/
drwxr-xr-x root/wheel 0 2010-02-14 22:29:22 System/Library/StartupItems/LoadCrystalHD/
-rwxr-xr-x root/wheel 221 2010-02-14 22:29:22 System/Library/StartupItems/LoadCrystalHD/LoadCrystalHD
-rwxr-xr-x root/wheel 124 2010-02-14 22:29:01 System/Library/StartupItems/LoadCrystalHD/StartupParameters.plist
-rwxr-xr-x root/wheel 240 2010-02-26 04:54:14 System/Library/Extensions/._BroadcomCrystalHD.kext
drwxr-xr-x root/wheel 0 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/
-rwxr-xr-x root/wheel 240 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/._Contents
drwxr-xr-x root/wheel 0 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/
-rwxr-xr-x root/wheel 240 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/._Info.plist
-rwxr-xr-x root/wheel 1327 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/Info.plist
-rwxr-xr-x root/wheel 240 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/._MacOS
drwxr-xr-x root/wheel 0 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/MacOS/
-rwxr-xr-x root/wheel 240 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/MacOS/._BroadcomCrystalHD
-rwxr-xr-x root/wheel 99348 2010-02-26 04:54:14 System/Library/Extensions/BroadcomCrystalHD.kext/Contents/MacOS/BroadcomCrystalHD
drwxr-xr-x root/wheel 0 2010-02-26 07:18:24 usr/
drwxr-xr-x root/wheel 0 2010-02-26 07:19:06 usr/bin/
drwxr-xr-x root/wheel 0 2010-02-26 06:26:22 usr/lib/
-rwxr-xr-x root/wheel 240 2010-02-26 06:26:58 usr/lib/._bcmFilePlayFw.bin
-rwxr-xr-x root/wheel 2786404 2010-02-26 06:26:58 usr/lib/bcmFilePlayFw.bin
-rwxr-xr-x root/wheel 240 2010-02-26 06:27:18 usr/lib/._libcrystalhd.dylib
-rwxr-xr-x root/wheel 69776 2010-02-26 06:27:18 usr/lib/libcrystalhd.dylib
-rwxr-xr-x roger/staff 18272 2010-02-26 07:19:06 usr/bin/kextstat
Hej i got into abit of problem i got my broadcom card today and opend my apple tv an inserted in did and new patchstick this time with ssh (dident have it installed without the card) inserted the cardand did what you shall do to get the xbmc working. i updated it all and now to the update of driver to the crystal hd card. i did those 2 steps andy have in the beggining of this thread. worked fine. i updated the driver from the loader (worked without any problem) now to the xbmc thingy i dont have the nightly build option in the launcher - downloads and if i start the xbmc i can not see the crystal hd card. my options in the dowloads section is
XBMC 9.11
Boxee beta 0.9.21.11497
Launcher 3.2.5
CrystalHD Driver r26
earlyer in this post davilla ask someone to run a ssh command i did that and got
login as: frontrow
[email protected]'s password:
Last login: Fri Jun 18 15:16:23 2010
-bash-2.05b$ defaults read com.teamxbmc.xbmclauncher XBMCAdditionalDownloadPlistURLs
("http://crystalhd.sartori.at/files/crystalhd.plist")
-bash-2.05b$
thx for any help i can get
ohh so you had to add the download line your self hehe abit of a noob when it stuff like this
anyway i have bean looking at 2 mkv movies now and one 720 and the other one 1080 the 720 worked realy good but the 1080 lagged in some places nothing big but anyway. nothing some updates can take care of i beleave
nice done xbmc crew and i realy mean it
Hello , I´m a noob user, and installed step by step ( I think so) the Crystal HD driver, I´ve got an apple Tv under 3.0.2 version, ATv flash 4.1.3.2 version, Xbmc launcher 3.2.5, svn r31294.
The problem is that i can´t play 720p or 1080p movies, mkv neither mp4.
When I go to XBMC/ system settings /video /playback I see in render method Auto detect and other options but not crystal HD, I´ve got an option marked "allow hardware acceleration crystal hd", but when I play a 720p video is very slow and not smooth.
I bought the 970012 card in ebay seller, and I must be sure that my card is not defective.
I´ve got an imac with snow leopard and thi is the log i see by ssh:
http://pastebin.com/saVNZPA5
Thank you for your help!
Been running crystal HD for a while. Everything was cool. Updated to newest SVN of XBMC, and now the video renderer says auto detect and there is a radio button for enable crystal hd. On my sample video, playback is not as good as it was at r28256.
Do I need to rerun the launcher script for Crystal HD r26? If so, do I need to remove currently installed drivers? Are there any other settings I need to adjust?
Crystalhd setting moved out of video renderer setting into it's own radio button. Nothing has changed (yet) in CrystalHD driver/lib so there's no gain in reload it.
davilla Wrote:Crystalhd setting moved out of video renderer setting into it's own radio button. Nothing has changed (yet) in CrystalHD driver/lib so there's no gain in reload it.
Thanks man. Maybe some non crystal hd stuff has changed in the latest SVNs and that is what is affecting playback? Who knows.
I am really being nitpicky, as your drivers saved my apple tv from becoming a really sweet paperweight.
Thanks for all of your efforts.
