Full Version: [Live] Default to external monitor on HP DV6710ea laptop.
As per the topic, I'm running Camelot on a HP DV6700. Everything runs perfectly on the laptops screen, but I cannot get a satisfactory picture from the monitor hooked up to the laptops VGA connector.
If I use the Function keys on the laptop, I can get XBMC to display, but it's at the resolution of the laptops screen, which is no good.
A) Is there any way I can get it to start up on the monitor instead of the laptop, and at the resolution of the monitor, not the laptop screen.
or
B) I don't mind having to manually switch it over, just so long as I can get it to output at the right resolution for the monitor!
It's running an Nvidia GeForce 7150M.
Shameless bump.
