2010-02-05, 12:00
2010-02-05, 12:00
2010-02-05, 15:40
2010-02-05, 16:08
michaeldecharon Wrote:I'm using the WallStream Mod V2 for Confluence into Rapier...
And it works like a charme!
Can you explain how you did that please?
Thanks,
Dave
2010-02-05, 23:30
thats cool, how can i make it work in warp info mode?
2010-02-05, 23:54
just download the mod and go to your skins folder and update the 720 and media folder with the new files. Make sure you backup your old files incase something goes wrong.
2010-02-06, 01:13
somthing went wrong' good thing i backed it up...
well it dosent work...
still hoping some one make a mod so it will work in warp info mode.
2010-02-06, 03:33
just curious what color should be used for other sources...
red case for HDDVD? what about HDTV captures, gray case?
2010-02-06, 03:50
HDDVD is red yes, but HDTV will probbly be shiped on bluray disks, so there is no such real case(grey HDTV)...
i will be happy with just BLURAY FOR 720 and up, cuz HDDVD is going away from this world...
2010-02-06, 13:01
I have uploaded a test version of my mod that adds these overlays for the Full Wall View.
What other views would you want this in. I don't think it would be very good in any views where the cover is small.
2010-02-07, 02:56
Version 3.17 of Qualar Mod uploaded.
Added Case overlays to WallView, List Info View and List Info View 2 (Wall).
All are enabled/disabled in there view options.
