Hay everyone i have try to search for XBMC for XBOX on googel i have no problem to find the SVN for it.
But is it not any way that just builded whit "XBMC 9.11: Camelot" so you know you dont need to espect any big bugs or any unstabel system
Thx for the help
/ Anton
google "xbmc nightly" or "t3ch"
Install T3CH Upgrader script using the XBMC Zone Installer in my singature - that helps you download and install a new XMBC build (T3CH or SSHCS nighly build - stick with T3CH for now, SSHCS is going through some changes to ZIP archives, not yet working) - all directly from the running XBMC. The new XBMC is installed in a separate folder so you can try it before making it your default dashboard. The script also is able to update the XBMC shortcut tool configuration to make the new XBMC as a default dashboard.
Users thx for the help but it was not what i asked for? Are it not any build whit final build "XBMC 9.11: Camelot" or is it only CVS for XBOX version?
Damn my 37 post will not know how mutch crap i have posted :/
antonstarlid
XBMC Team cannot distribute binary builds for legal reasons, they can only write the code. Thus there is no official XBMC 9.11 Camelot build from XBMC. Your best bet is to use one of the builds available on the Internet - T3CH or SSHCS (or others), or build it yourself from code.
http://wiki.xbmc.org/?title=HOW-TO_compi...ource_code
