Full Version: Changing 'Approx Ending Time' text?
I am getting on nicely with my mod. However I have hit a small hurdle.
I have increased the font size for the skin by quite a bit as my other half has quite bad eye sight. The only problem that has occurred is the 'approx ending time' label on the video player controls moved slightly out of view.
I intended to change 'Approx Ending Time' to 'Approx End Time' as a compromise. However I can't find the place to change this text within my folders.
Can anyone point me in the right direction please? I may also need to nudge it slightly to the right, advice on that would be appreciated as well.
Cheers
Steve
Ok, I have solved it.
For future reference the text is included in the strings.xml file in the following folder...
Back-Row\language\English
Okay here you go:
The text is located in the strings.xml file located in the folders - \language\English - it's line 52.
Moving that text to the right would require editing of the VideoOSD.xml file located in the Pal folder.
You'd need to edit the x coordinate of that label -line 368
Cheers
edit - you beat me to it Smile
lol, cheers Sharpe. Smile
