I have three minor issues with alaska that all are caused by me running 9.11 live, and the alaska release also stated that a newer verson is required.
I can't seem to find a proper guide on how to update 9.11 live to latest svn. Can someone point me somewhere?
I think I need to put the svn ppa in my sources list (from here:
http://forum.xbmc.org/showthread.php?tid=33327) and then run sudo apt-get update, sudo apt-get upgrade and install xbmc. Just a little afraid to try as My systems is running fine except for some minor visual glitches. Is this the way to go?
as discussed in another thread just moments ago
add this to your /etc/apt/sources.list
deb http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu karmic main
deb-src http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu karmic main
register the key for the added ppa:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 64234534
then:
and
if upgrade does not work
sudo apt-get dist-upgrade
if you only want to upgrade the xbmc parts (not _all_ upgrade-able packets)
sudo apt-get install xbmc
also as gabbott said is the bugs thread, if you get an open_gl error with a full dist upgrade, do this:
cd /usr/lib/xorg/modules/extensions
sudo mv libglx.so libglx.so.default
sudo ln -s libglx.so.1 libglx.so
Just did it. I got a small (unreadable) window after reboot.Font was to small. I could use putty to approach system and did the opengl fix.
Now it boots, I see the spinning logo, then the big logo and the mouse cursor and right when I should see alaska it cycles back to the logo and this continues indefinitely. no errors. Any clue on how to fix?
kept it looping for an hour, rebooted and it works. pfew.
kees667 Wrote:Just did it. I got a small (unreadable) window after reboot.Font was to small. I could use putty to approach system and did the opengl fix.
Ok I am now getting the same small box on my screen as you describe.
Can you explain the steps you used to resolve that to make it viewable?
328iGuy Wrote:Ok I am now getting the same small box on my screen as you describe.
kees667 Wrote:kept it looping for an hour, rebooted and it works. pfew.
I am getting this same looping now. Tried rebooting, same thing?
I cant get it to stop either. $%$#$ I hope I Dont need a re-install!! argh!
I did what is in the last two code boxes above. also at some point my system mentioned I could execute a command with "remove" in it. That all ended up in endles looping.
I then burned a new iso to reinstall, but couldn't place it quick enough in my asrock so it ended up booting from harddisk again and that suddenly worked.
I did not do dist-upgrade as it messed up something last time.
kees667 Wrote:I did what is in the last two code boxes above. also at some point my system mentioned I could execute a command with "remove" in it. That all ended up in endles looping.
You see, I made the mistake of running all the code boxes above. I think I am going to have to re-install all over now
Thank you Calmdown. This worked great!
I did need to run apt-get install xbmc-live at the end to update xbmc.
Me too... and thanks for the xbmc-live tip.
