I've been running Karmic on my ATV with a CrystalHD card for quite a while and all of a sudden I'm having huge thrashing problems (swapping).
I'm not sure whether it's the new SVNs or updates I did for karmic. I made the mistake of updating Karmic yesterday and rebuilding SVN at the same time. SVN from yesterday afternoon had the same problems as todays (not sure on revision exactly yesterday).
Playback is almost hopeless at this point. Even going through the movie list is VERY VERY slow. Switching movies takes a few seconds, switching pages of movies takes almost 10. If playback ever starts it's about a frame every 5 seconds, and takes a good minute to start. CrystalHD card claims to be activated in the logs, but the system is so jacked it doesn't matter.
Anyone have any ideas or experiencing the same problems?
EDIT: Further notes. I updated my Revo with Karmic at the same time, and rebuilt SVN on that at the same time as well and am not experiencing the same problems. I'm almost certain it's memory related, but I can't see anything running taking up a ton of the RAM.
Anyone?
Problem still persists with R27543.
iotop during startup of movie
TID PRIO USER DISK READ DISK WRITE SWAPIN IO> COMMAND
55 be/4 dan 709.60 K/s 0.00 B/s 0.00 % 0.00 % xbmc.bin --standalo
4996 be/4 dan 1310.04 K/s 0.00 B/s 0.00 % 0.00 % xbmc.bin --standalo
670 be/4 haldaemo 915.10 K/s 0.00 B/s 0.00 % 0.00 % hald --daemon=yes
5157 be/4 dan 455.94 K/s 0.00 B/s 0.00 % 0.00 % xbmc.bin --standalo
5158 be/4 dan 420.63 K/s 0.00 B/s 0.00 % 0.00 % xbmc.bin --standalo
5161 be/4 dan 179.81 K/s 0.00 B/s 0.00 % 0.00 % python /usr/bin/iot
1687 be/4 dan 3.21 K/s 0.00 B/s 0.00 % 0.00 % sshd: dan@pts/1
5017 be/4 dan 102.75 K/s 0.00 B/s 0.00 % 0.00 % xbmc.bin --standalo
1 be/4 root 0.00 B/s 0.00 B/s 0.00 % 0.00 % init
vmstat 1 during startup of movie... the swapping stopping is when the movie finally started after a couple of minutes (it's an SD movie so it actually played, and perfectly once it got going.)
procs -----------memory---------- ---swap-- -----io---- -system-- ----cpu----
r b swpd free buff cache si so bi bo in cs us sy id wa
3 2 135096 3456 376 22548 528 324 1173 456 3842 1674 26 4 10 60
2 1 130700 4056 392 22924 552 0 1672 24 5668 2571 31 3 0 66
0 3 130668 3696 436 22740 276 0 2388 0 5044 2497 27 5 0 68
3 2 130640 3096 496 23168 152 0 2172 0 4906 2417 28 5 0 67
1 2 130640 3652 556 22152 356 0 2788 0 5328 2503 29 6 0 65
2 2 130284 4180 508 20608 1228 0 1388 0 6460 2647 27 9 0 64
1 3 129780 3440 512 21204 728 0 1992 24 5128 2517 32 7 0 61
4 0 105296 6692 512 22040 436 0 1948 0 5020 2450 32 4 0 64
4 0 105196 4892 512 23604 192 0 192 0 4776 977 89 10 0 1
2 1 105208 4256 452 24356 0 12 0 12 3138 2177 45 7 35 13
4 0 105204 4256 452 24356 4 0 4 0 4928 2250 40 10 46 4
2 0 105204 4256 460 24348 0 0 0 24 4376 2320 40 8 52 0
Well it turns out I wasn't imagining things. The Ubuntu guys decided to add their own readahead project called ureadahead and remove sreadahead in Karmic (the stable tree). There are a couple of bugs.
1. After upgrading/installing/removing certain packages the ureadahead cache is rebuilt the next reboot. During this boot a bunch of memory is used to build the cache. That memory is never returned to the system until another reboot happens (this can be substantial amounts of RAM).
https://bugs.launchpad.net/ubuntu/+sourc...bug/501715
2. If your system doesn't have enough RAM for the cache to be built, an out of memory error will be thrown during bootup. The memory used before the error is thrown is not released and the boot continues with very little remaining RAM. (This is the one that pegged me on the ATV).
https://bugs.launchpad.net/ureadahead/+bug/491943
To give you an idea of the difference... this is the system running with Xorg, and xbmc-standalone with and without ureadahead installed.
With ureadahead
dan@atv-ubuntu910:~$ free -m
total used free shared buffers cached
Mem: 241 233 8 0 1 21
-/+ buffers/cache: 210 31
Swap: 1054 71 982
Without ureadahead
Mem: 241 233 8 0 4 84
-/+ buffers/cache: 144 96
Swap: 1054 3 1051
My fix was to remove ureadahead, delete files /etc/init/ureadahead* since the kernel modules seem to want to run anyway, and reboot.
Maybe this info will help someone else...
