I am currently using openelec on an intel NUC. I have created the script file and copied it to my installation inside the userdata folder and modified it to point to a directory of files on my hard drive. Then I created a function on xbmc home menu that runs RunScript(Special://profile/autoplaydir.py) but it just returns "script failed". Any ideas?
(2014-10-13, 10:32)yvanof Wrote: [ -> ]found solution:
Quote:# Autoplay videodirectory
import os, xbmc
# set path to dir you want to play
path="/mnt/SATA Disk #1 GeeXboX (0)/media/"
dirList=os.listdir(path)
dirList.sort()
videoList = xbmc.PlayList(xbmc.PLAYLIST_VIDEO)
videoList.clear()
for fname in dirList:
videoList.add(path + "\\" + fname)
# shuffle playlist
#videoList.unshuffle()
# put playlist on repeat
xbmc.executebuiltin("xbmc.playercontrol(RepeatAll)")
# play playlist
xbmc.Player().play(videoList)
i have downloaded this script on my pi board, but it doesn't work and an error message apears on screen.
is the syntax of this script true.
for example '\' and '/' in two sections of code.
is there a final version of this script (that was written correctly) without errors.
thanks
Hi, i have the script working but i would love to be able to play a directory on my nas, i'm using NFS.
But any way i've tried this, the script doesn't do anything or gives me an error.
Does anybody know how i have to refer to my NFS folder when using this or another script?
The reason why i want to do this is because i want to be able to change the files on the nas and have multiple pi's play them, without having to copy the files to multiple devices.
thanks so much !!
I wanted to run a youtube play list with shuffle. Apparently the shuffle is not working very well in this .m3u file. I found out that by toggling the shuffle ON and OFF I get a shuffled list, hence I've blased the shuffle in a for loop that runs a random number of iterations. Next I've added a shortcut in the favourites.xml file for the script
import os, xbmc, xbmcgui,random, time, xbmcaddon
path="C:\\Users\\19009843\\AppData\\Roaming\\Kodi\\userdata\\playlists\\video"
videoList.clear()
videoList.load(path+"\\grunge.m3u")
t=random.randint(1, 100)
# shuffle playlist
for x in range(0, t):
videoList.shuffle()
videoList.shuffle()
# play playlist
Hope this helps...
Tzahovy
Hi, thanks for script,
I am using it to play various materials found on network drive (including pptx and jpg through external players).
How can I achieve restart of kodi on changing of folder contents (or dynamic loading files into that playlist)?
regards,
R
The sript that worked for me:
# -*- coding: utf-8 -*-
import os, xbmc
path='/home/osmc/Movies'
dirList.sort()
videoList.clear()
videoList.add(path+'/'+fname)
# shuffle playlist
xbmc.executebuiltin('xbmc.playercontrol(RepeatAll)')
# play playlist
Does anyone knows how can i update the playlist automatically (crontab?) without rebooting?
Thanks in advance!
