Add the "(2009)" to the tv shows root folder.
anyone have any other ideas on how to get this to scrape?
tvdb has like 12 entries for this thing, and I keep getting the nbc series.
edit: figure it out...
named the folder Life (2009)
each file named "Life (2009) - E01.mkv"
You can use a "
Supplemental Tool" to scrape any piece of media, and it will create a .nfo file alongside the media for you, which XBMC will look into for the information of said media instead of looking at the actual media file. If the program scrapes the media incorrectly, you can change it to the correct entry within the program and XBMC will read it correctly then.
My favorite program to do this is
Media Companion. Many of the programs that do this are very mature.
I changed the file names to BBC Life which worked for me.
can anyone comment on what works for them naming this directory and files? i have tried all these methods but i still cannot get the correct listing and episodes. also where you scrapping from?
Life (2009) as the folder name works just fine using thetvdb.com
jmarshall Wrote:Life (2009) as the folder name works just fine using thetvdb.com
i do not know why this it not working for me. what do you have your file names listed in the foldeR? It scrapes the LIFE folder fine...but doesn't recognize any of the files inside
Should look something like this.
Life (2009)
- s01e01.avi
- s01e02.avi
- etc
