2010-02-08, 15:52
hey all,
i already found a couple of threads related to this topic, but it wasn't clear to me whether this problem is officially solved or not.
my current configuration:
- asus nvidia ion 330 board
- x11-drivers/nvidia-drivers-190.53-r1
- x11-libs/libvdpau-0.3-r2
- xbmc svn rev. 27571
- internal libs enabled / external disabled
- gui resolution 1920x1080 @ 60hz
- adjust refresh rate enabled
- a/v sync method: audio
- vertical blanc sync: let driver decide
first of all all kind of videos work without any flaws, mkv (avc1), too. i have a couple of m2ts bluray streams (wvc1) which are the troublemakers atm.
as soon as i would start to playback one of the m2ts files, xbmc would switch the refresh rate to 24hz resulting in some kind of "jumpy" playback. don't know if there is any term to describe this behaviour, it's like the video is going one frame forward and three frames backwards.
situation1:
- see above
- error in debug log:
situation2:
- adjust refresh rate disabled
-> playback of m2ts and all other video formats, hd and sd, works fine. the refresh rate stays at 60hz like expected.
situation3:
- gui resolution 1920x1080 @ 24hz
-> playback of m2ts and all other video formats, hd and sd, works fine. the refresh rate stays at 24hz like expected while playing back 24hz hd content. the refresh rate switches to 50/60hz while playing back sd content. the disadvantage is a really slow and laggy gui, just like expected.
is there anything i could do to get m2ts files played back correctly in conjunction with a refresh rate switch?
is this a known problem and maybe work in progress?
btw is it quite normal that xbmc misses about 40 video frames while switching to the appropriate refresh rate?
i attached three debug logs for each of the situations above.
situation1: http://pastebin.com/mf0a3a6c
situation2: http://pastebin.com/m45de5348
situation3: http://pastebin.com/m34ce0134
regards,
einhänder
situation1:
- see above
14:33:51 T:2866559856 M:2970103808 ERROR: VDPAU Device Preempted - attempting recovery
14:33:51 T:2866559856 M:2970103808 ERROR: (VDPAU) Error: The display was pre-empted, or a fatal error occurred.(2) at VDPAU.cpp:1058
situation2:
situation3:
regards,
einhänder
