2010-02-08, 22:51
I'm having some problems setting up my iMON PAD remote as an universal remote (I want to use all my buttons).
I'm using the lircd.conf provided with lirc for my remote (/usr/share/lirc/remotes/imon/lircd.conf.imon-pad) and every button works fine when tested with irw.
Following this guide I've created a $HOME/.xbmc/userdata/Lircmap.xml and a $HOME/.xbmc/userdata/keymaps/remote.xml.
However I can't get all buttons to work and if I check the log file I see the following:
It compains about not finding some windows and I'm not sure what's wrong. And should it really load the Lircmap.xml after the remote.xml file?
Pressing the buttons shows that they do get read from lirc:
Yet I can't change audio/subtitles with my remote. Can someone please tell me what I'm doing wrong? I can post a complete debug log if needed be.
I'm running XBMC svn revision 27423 and Arch Linux 64-bit.
21:22:57 T:139993613666368 M:4057264128 INFO: load keymapping
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/keymaps/remote.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://masterprofile/keymaps/remote.xml
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window fullscreenobc48
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window videoobc15
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window contextobc15
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window scriptsdebugobc48
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window systemobc48
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window shutdownobc15
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window subobc15
21:22:57 T:139993613666368 M:4057264128 ERROR: Window Translator: Can't find window pictureobc48
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://profile/keymaps/remote.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://xbmc/system/Lircmap.xml
21:22:57 T:139993613666368 M:4057264128 INFO: Loading special://profile/Lircmap.xml
21:47:09 T:139993613666368 M:3966369792 DEBUG: LIRC: Update - NEW at 1451992:000000002b8595b7 00 Language iMON-PAD (Language)
21:47:10 T:139993613666368 M:3966369792 DEBUG: LIRC: Update - NEW at 1453004:00000000298595b7 00 Caption iMON-PAD (Caption)
