Full Version: ATSC With Grey Border?
Whenever I play back ATSC files created by Windows Media Center on XBMC, I get a gray border on the bottom of the screen. The same files played back on MPC-HC or WMP don't have this visual anomaly. I'm curious if it's due to the embedded text stream. Is there any way to fix this?
XBMC
WMP
Here is the file info:
General
Format : MPEG-PS
File size : 4.96 GiB
Duration : 39mn 3s
Overall bit rate : 18.2 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@high
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 39mn 3s
Bit rate mode : Variable
Bit rate : 17.1 Mbps
Nominal bit rate : 65.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.275
Stream size : 4.66 GiB (94%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 39mn 3s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 107 MiB (2%)
Text
ID : 224 (0xE0)-608-1
Format : EIA-608
Muxing mode : MPEG Video / EIA-708
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
I would need a sample to figure that out.
