Full Version: scrapers not working
Hi
I'm slowly fixing all my issues on my newly built Revo with XBMC Live install.
But failing to understand how the scrapers work ?
I have copied over a film called Toy story onto the HDD and can't get any movie information about it ?
Could someone please explain how this all works?
I have a internet connection and the RSS feed down the button is working fine.
Smile
1. Provide debug log of scan.
2. Provide details of your file and folder structure.
3. Confirm your scraper settings.
prae5 Wrote:1. Provide debug log of scan.
Hi please go easy with me, i'm new 8)
The file is copied on my HDD in /home/xbmc/toy story.mkv
My scraper settings
default movie IMDb.com ( i did try themoviedb.org )
default tvshow TheTVDB.com
default music video MTV
enable fallback based on scraper language ( unticked )
Below is my debug log file. After a clean reboot I select the movie from videos/movies and from the drop down menu selected movie information and then toy story, but nothing
I not really sure how this works so could do with a few pointers as well please, should this be a automatic process ?
00:55:13 T:3077949328 M:699449344 NOTICE: -----------------------------------------------------------------------
00:55:13 T:3077949328 M:699449344 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Dec 24 2009 (SVN:26018)
00:55:13 T:3077949328 M:699449344 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
00:55:13 T:3077949328 M:699449344 NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
00:55:13 T:3077949328 M:699449344 NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
00:55:13 T:3077949328 M:699449344 NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
00:55:13 T:3077949328 M:699449344 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
00:55:13 T:3077949328 M:699449344 NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
00:55:13 T:3077949328 M:698781696 NOTICE: Setup SDL
00:55:14 T:3077949328 M:698085376 NOTICE: load settings...
00:55:14 T:3077949328 M:698085376 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:55:14 T:3077949328 M:698085376 NOTICE: loading special://masterprofile/guisettings.xml
00:55:14 T:3077949328 M:697585664 NOTICE: Getting hardware information now...
00:55:14 T:3077949328 M:697585664 NOTICE: Checking resolution 12
00:55:14 T:3077949328 M:697733120 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
00:55:14 T:3077949328 M:697733120 NOTICE: Loaded playercorefactory configuration
00:55:14 T:3077949328 M:697733120 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
00:55:14 T:3077949328 M:697733120 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:55:14 T:3077949328 M:697733120 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
00:55:14 T:3077949328 M:697733120 NOTICE: Default DVD Player: dvdplayer
00:55:14 T:3077949328 M:697733120 NOTICE: Default Video Player: dvdplayer
00:55:14 T:3077949328 M:697733120 NOTICE: Default Audio Player: paplayer
00:55:14 T:3077949328 M:697733120 NOTICE: special://masterprofile/sources.xml
00:55:14 T:3077949328 M:692998144 NOTICE: Using fbConfig[0]
00:55:14 T:3077949328 M:691716096 NOTICE: GL_VENDOR = NVIDIA Corporation
00:55:14 T:3077949328 M:691716096 NOTICE: GL_RENDERER = ION/PCI/SSE2
00:55:14 T:3077949328 M:691716096 NOTICE: GL_VERSION = 3.2.0 NVIDIA 190.53
00:55:14 T:3077949328 M:691716096 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
00:55:14 T:3077949328 M:691716096 ERROR: GLX: Same window as before, refreshing context
00:55:15 T:3077949328 M:690470912 NOTICE: HAL: Generating global device list
00:55:15 T:3077949328 M:690429952 NOTICE: start dvd mediatype detection
00:55:15 T:3077949328 M:690429952 NOTICE: initializing playlistplayer
00:55:15 T:3077949328 M:690429952 NOTICE: DONE initializing playlistplayer
00:55:15 T:3077949328 M:690429952 NOTICE: load default skin:[Confluence]
00:55:16 T:3077949328 M:684482560 NOTICE: UpdateLibraries - Starting video library startup scan
00:55:16 T:3077949328 M:684228608 NOTICE: initialize done
00:55:16 T:3077949328 M:684228608 NOTICE: Running the application...
00:55:16 T:3077949328 M:684060672 NOTICE: ES: Starting event server
00:55:16 T:3077949328 M:684060672 NOTICE: DS: Starting dbus server
00:55:16 T:3012008816 M:684060672 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
00:55:16 T:3012008816 M:684060672 NOTICE: UDP: Listening on port 9777
00:55:16 T:3077949328 M:683663360 ERROR: DS: Failed to connect to the D-Bus session daemon: Empty address ''
00:55:16 T:3077949328 M:683663360 NOTICE: starting zeroconf publishing
00:55:16 T:3043478384 M:684732416 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:00
00:56:18 T:2977770352 M:667193344 NOTICE: -->Python Interpreter Initialized<--
Many Thanks
I am also having problems with the scraper.
The Boxee scraper is extremely fast and quite accurate but the XBMC scraper is painfully slow and doesn't seem to retrieve much art.
Is there an external scraper like movingpictures on media portal has?
