malte Wrote:@phsyraxion: You could add a batch file to your launch process.
1. Write a simple batch file that kills YATSE at first and then starts your emulator. You can use "*%" (without "") to access the params passed by RCB.
2. Launch this batch file instead of the emulator from RCB.
Thanks for the reply
I thought about doing this but then wondered if I launched a batch script and used that to launch the emulator would the game be passed to the EMU?
Anyways, what I have tested is using the standalone emu mode (which uses the applaunch.bat file) and adding extra options in that and that works fine.... To a degree.
Here is the issue I have (small but annoying)
I would like to not have to close XBMC to play a game (happy to have it run in the background) and it all works fine with XBMC running in the background and I am passed straight back and all seems good (I disabled the code that kills XBMC)
I have the "screensaver" feature in XBMC active and it seems that when this kicks in it screws up the browser plugin. When I return from a game the games have no details and the navigation doesn't work properly. If I exit out of the script I cannot open it again and am forced to restart XBMC.
Is there any way to disable the screensaver of XBMC when in this plugin? I don't want to disable it completely in XBMC and i'd rather not have to close XBMC every time I launch a game but may have to...
EDIT: further to this I am unable to launch XBMC after it is closed by RCB.
I have found in this thread that I need to add EXPLORER to the start of the string, which I have and it"works" but I get the windows explorer file security dialogue popup. Now, I can disable this warning easy enough but then here is the next issue. I run XBMC in portable mode so I need the -p switch.
If I try:
EXPLORER "C:\Program Files\XBMC\xbmc.exe -p"
EXPLORER "C:\Program Files\XBMC\xbmc.exe" -p
It cannot find the path.
If I try and launch an AutoIT script to launch XBMC I get the cApplication error but launching the autoit script myself works just fine.
EDIT2: Further to this, when I have the option to load RCB on next XBMC load it is creating the autoexec.py file but on every load I get an error with this file and it doesn't open RCB.
The contents of the file are:
AUTOEXEC.PY:
#Rom Collection Browser autoexec
import xbmc
xbmc.executescript('C:\Program Files\xbmc\portable_data\Addons\script.games.rom.collection.browser\default.py')
LOG WHEN LOADING XBMC AND GETTING ERROR:
http://pastebin.com/PvctRFDJ
