(2015-02-18, 09:07)malte Wrote: [ -> ]New test version available: 2.1.1
List of changes:
General- kodi compatibility: fix label positions in missing info filter dialog
Browse Games- new option (addon settings): max number of games to display
Launch Games- new option (edit rom collection): make local copy (thanks to sklick)
I forgot one dialog that still showed some blank items, I hope I have them all fixed now. I also added two more options: "max number of games to display" will help users with large collections to limit the number of games that are displayed in the ui, "make local copy" will copy the rom file to a local temp dir before the emulator is launched. This should help users that have issues with launching roms from external sources.
Previous version: 2.1.0
thank you malte fot this update. I have selected 100 games to display but
I don't understand how to access to the next 100 games in my large rom mame collection .
thank you for your answers
Is there a way to ignore error pop ups while importing collections? I'm getting pop about writing xml for a specific rom while importing collection, this halts import. I'm hoping i can just ignore these as my libraries are quite large.
nalias Wrote:O, i hope I am not missing some obvious xbmc setting.. but is it possible to run the import scan in the back ground? Can it be 'detached' from xbmc as a separate program/script that is updating the same db xbmc is reading?
You can try
the background scraping option in Addon settings. But I haven't tested it for a long time to be honest
mikty Wrote:hank you malte fot this update. I have selected 100 games to display but
It does not work like paging. It will show x number of games and thats it. Everything else you have to do with additional filters or larger numbers.
geopgin Wrote:Is there a way to ignore error pop ups while importing collections?
No, there is no option like this atm.
(2015-02-19, 16:25)malte Wrote: [ -> ]geopgin Wrote:Is there a way to ignore error pop ups while importing collections?
Thanks Malte,
Is this a valid work around
"As an advance workaround, you can comment out line 1207 of \resources\lib\dbupdate.py to suppress the error dialog (it will still be logged in the xbmc.log)."
https://code.google.com/p/romcollectionb...20Modified.
Also do you prefer to post issues here or have them logged in code.google?
EDIT: now line 1211
Update: Ignore this post, thanks to nalias who pointed out that my configuration was off.
Okay..
(2015-02-19, 18:10)geopgin Wrote: [ -> ] (2015-02-19, 16:25)malte Wrote: [ -> ]geopgin Wrote:Is there a way to ignore error pop ups while importing collections?
Thanks Malte,
EDIT: now line 1211
So the above worked...but now i have another issue. Since upgrading to 2.1.1 (because of issue
Here ) I can no longer launch roms. They were working before updated rcb. I tried popen and solo mode...no joy. If i take the cmd and run manually it works.
See logs snips
18:13:20 T:4100 NOTICE: RCB_INFO: files for current game: [(u'C:\\Games\\Roms\\NES\\1942 (JU).nes',)]
18:13:20 T:4100 NOTICE: RCB_INFO: launcher.buildCmd
18:13:20 T:4100 NOTICE: RCB_INFO: emuCommandLine: C:\Games\retroArc\RetroArch-v1.0.0.2-64-bit\retroarch.exe
18:13:20 T:4100 NOTICE: RCB_INFO: preCmdLine:
18:13:20 T:4100 NOTICE: RCB_INFO: postCmdLine:
18:13:21 T:4100 NOTICE: RCB_INFO: Getting Multiple Disc Parameter
18:13:21 T:4100 NOTICE: RCB_INFO: emuParams: -f -L "C:\Games\retroArc\RetroArch-v1.0.0.2-64-bit\cores\snes9x_next_libretro.dll" "%ROM%"
18:13:21 T:4100 NOTICE: RCB_INFO: rom: C:\Games\Roms\NES\1942 (JU).nes
18:13:21 T:4100 NOTICE: RCB_INFO: No precmd created.
18:13:21 T:4100 NOTICE: RCB_INFO: No postcmd created.
18:13:21 T:4100 NOTICE: RCB_INFO: cmd: call "C:\Games\retroArc\RetroArch-v1.0.0.2-64-bit\retroarch.exe" -f -L "C:\Games\retroArc\RetroArch-v1.0.0.2-64-bit\cores\snes9x_next_libretro.dll" "C:\Games\Roms\NES\1942 (JU).nes"
18:13:21 T:4100 NOTICE: RCB_INFO: precmd: call
18:13:21 T:4100 NOTICE: RCB_INFO: postcmd: call
18:13:21 T:4100 NOTICE: RCB_INFO: launchEmu on non-xbox
18:13:21 T:4100 NOTICE: RCB_INFO: screenMode: 1440x900@ 50.00 - Full Screen
18:13:21 T:4100 NOTICE: RCB_INFO: Toggle to Windowed mode
18:13:21 T:4100 NOTICE: RCB_INFO: launch emu
18:13:21 T:4100 NOTICE: RCB_INFO: onAction: 100
18:13:21 T:4100 NOTICE: RCB_INFO: onAction: 107
18:14:12 T:4100 NOTICE: RCB_INFO: launch emu done
18:14:13 T:6912 NOTICE: Found 2 Lists of Devices
18:14:13 T:6912 NOTICE: Enumerated DIRECTSOUND devices:
18:14:13 T:6912 NOTICE: Device 1
18:14:13 T:6912 NOTICE: m_deviceName : {26021875-6560-4F5E-848C-1AEA4F539CB1}
18:14:13 T:6912 NOTICE: m_displayName : Speakers - Speakers (Conexant 20585 SmartAudio HD)
18:14:13 T:6912 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (Conexant 20585 SmartAudio HD)
18:14:13 T:6912 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:14:13 T:6912 NOTICE: m_channels : FL,FR
18:14:13 T:6912 NOTICE: m_sampleRates : 44100
18:14:13 T:6912 NOTICE: m_dataFormats : AE_FMT_FLOAT
18:14:13 T:6912 NOTICE: Device 2
18:14:13 T:6912 NOTICE: m_deviceName : default
18:14:13 T:6912 NOTICE: m_displayName : default
18:14:13 T:6912 NOTICE: Enumerated WASAPI devices:
18:14:14 T:6912 NOTICE: Device 1
18:14:14 T:6912 NOTICE: m_deviceName : {26021875-6560-4F5E-848C-1AEA4F539CB1}
18:14:14 T:6912 NOTICE: m_displayName : Speakers - Speakers (Conexant 20585 SmartAudio HD)
18:14:14 T:6912 NOTICE: m_displayNameExtra: WASAPI: Speakers (Conexant 20585 SmartAudio HD)
18:14:14 T:6912 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:14:14 T:6912 NOTICE: m_channels : FL,FR
18:14:14 T:6912 NOTICE: m_sampleRates : 192000,96000,48000,44100
18:14:14 T:6912 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
18:14:14 T:6912 NOTICE: Device 2
18:14:14 T:6912 NOTICE: m_deviceName : default
18:14:14 T:6912 NOTICE: m_displayName : default
18:14:14 T:4100 NOTICE: RCB_INFO: Toggle to Full Screen mode
18:14:14 T:4100 NOTICE: RCB_INFO: End launcher.launchEmu
18:14:14 T:4100 NOTICE: RCB_INFO: End launchEmu
And cmd err
http://imgur.com/gug0il6
geopgin - I could be dead wrong with how retroarch cores are working, but you're calling a NES game with a SNES core.. that works? Also, I would test to see if it works with roms that don't have the 'special' characters like space and bracket. Should also note that I too had the error on import, and applied the fix you found seems to work perfectly, not sure why a info notice throws up a user diag. anyway..
Launch is broken for me too, in gotham and only with zip files, if i turn off extract zips the launch command works.. sad because i love that feature.
Hey Nalias, thanks for that catch.That explains my NES issues, which i have since corrected. My SNES is still pooched but maybe its a config issue as well. I don't think i messed around with them since i patched rcb but i'm new to kodi/rcb/retroarch and just started playing with cpl days ago so i have been all over the place. I'll take another look tks. i'll post back ether way
EDIT: FIxed SNES, The library's got swapped around, not sure how i did that.
Can somebody show me a log file of unzipping not working? I tried every possible combination of zipped/unzipped/local copy on Gotham and Helix and I can't reproduce this error.
Here you go:
20:24:49 T:14440 NOTICE: RCB_INFO: files for current game: [(u'D:\\EMU\\SNES\\SNESROMS\\Zakuro no Aji.zip',)]
20:24:49 T:14440 NOTICE: RCB_INFO: launcher.buildCmd
20:24:49 T:14440 NOTICE: RCB_INFO: emuCommandLine: D:\EMU\SNES\snes9x-1.53-x64\snes9x-x64.exe
20:24:49 T:14440 NOTICE: RCB_INFO: preCmdLine:
20:24:49 T:14440 NOTICE: RCB_INFO: postCmdLine:
20:24:49 T:14440 NOTICE: RCB_INFO: Getting Multiple Disc Parameter
20:24:49 T:14440 NOTICE: RCB_INFO: emuParams: -fullscreen "%ROM%"
20:24:49 T:14440 NOTICE: RCB_INFO: rom: D:\EMU\SNES\SNESROMS\Zakuro no Aji.zip
20:24:49 T:14440 NOTICE: RCB_INFO: Trying to delete temporary rom files
20:24:49 T:14440 NOTICE: RCB_INFO: Treating file as a compressed archive
20:24:49 T:14440 NOTICE: RCB_INFO: The Archive has 3 files
20:24:56 T:14440 NOTICE: roms compressed = []
20:24:56 T:14440 NOTICE: RCB_INFO: No cmd created. Game will not be launched.
20:24:56 T:14440 NOTICE: RCB_INFO: End launchEmu
Hello everyone,
been using RCB for over a year now and never had issues. But since upgrading to Kodi I can't seem to solve some problems already mentioned in this thread before on my own. So here I am asking for some help.
I'm suffering from the exact same problem as described here:
(2015-01-04, 01:13)nektahiti Wrote: [ -> ] (2014-12-04, 23:16)jrbilodeau Wrote: [ -> ]I just loaded up RCB on KODI RC2 and configured a snes rom collection using snes9x on linux (ElementaryOS Luna) which is working, however once i go into RCB and press c to edit settings the is a bunch of text missing on the screen.
I am using the default skin that comes with XBMC.
I have the same issues. In most of the dialog boxes that should look like this:
All the right side options text are missing. So there is no way to know what scraper or option is selected when using the up/down arrows.
Any pointers on what's going on here?
Would also like to thank whoever it was that posted about changing the x/y to get the offset menus back where they belong
I already tried everything from replacing the XML-files like described in the following post. I also changed the x and y values myself but nothing solved my problem. Tried every version from 2.0.16 to 2.1.1 and reinstalled RCB multiple times.
(2015-01-08, 16:28)imro2 Wrote: [ -> ] (2015-01-05, 14:31)dr_phil Wrote: [ -> ] (2015-01-05, 11:46)Aurelien Wrote: [ -> ]Hi,
I have the same problem... could you send your modified files ?
I wonder why there is this problem, is there any change in Kodi layout management ? Because I think the problem should appears with a lot of plugins, not only Rom Colelction Browser...
I agree. It seems strange that the positioning would change between releases. It seems like it would be all or none too. So all the labels should be off. Also it seems like it's only the combo boxes/lists that are experiencing the issue.
The problem here is that the posx + width are grater than the width of the parent element. I am guessing Kodi used to fix wrongly defined elements and suddenly just stopped fixing them.
If I knew how I would attach my fixed XMLs.
Edit:
These are for version="2.0.17"
script-RCB-editromcollection.xml
script-RCB-editscraper.xml
script-RCB-importoptions.xml
script-RCB-missinginfo.xml
script-RCB-removeRC.xml
I am sure they are not 100% as author intended, but they are working and they will get you by until a real fix comes.
In addition, the nfo-files from some of my ROMs are not scraped correctly anymore.
For example when scraping Mario Kart 64 there is no chance to get the plot description.
Even though the old nfo-file with plot description is still there.
Help is much appreciated.
I am using Aeon MQ5 Mod skin for Helix right now.
Is it posible to hide command line window when I start the game? Maybe some workaround?
On some games like Mortal Kombat Komplete Edition this window displays up to 10 seconds and it doesn't look nice at all
@nalias: Thanks. Maybe there is an issue because there is more than 1 file in your archive. I guess I always tested with 1 file zips.
@Maaarv: Aeon MQ5 ships its own RCB skin files. So you need to make the changes in the files in the Aeon MQ5 skin directory. I will look into the nfo thing.
@Booch: Not as a feature in RCB. It didn't disturb me enough to investigate
(2015-02-20, 19:03)malte Wrote: [ -> ]@Booch: Not as a feature in RCB. It didn't disturb me enough to investigate
Ok, I know how to convert batch file to run it in invisible mode.
Maybe I can do a workaround myself with your little help, just point me where I should start if it's possible to replace some file with my executable file ?
Booch go to edit rom collection then click on launch games tab then select use popen, to launch emulator to see if it helps.
(2015-02-20, 20:27)joebloggs12 Wrote: [ -> ]@Booch go to edit rom collection then click on launch games tab then select use popen, to launch emulator to see if it helps.
you are genius! command line window disappears now. thank you!
