2015-04-12, 14:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395
2015-04-13, 07:02
Hi all,
sorry for the lack of response again. I hope that I will be back in 1-2 weeks.
@aquiles2k: I saw that you want to get into some coding stuff. That would be great. I hope that I can give you some guidance in a couple of days. Before you start to dig too deep in certain issues (like thegamesdb api) we maybe should discuss this per PM first as there are some changes in the pipe that might make your work obsolete in later releases.
Regards,
malte
Regards,
malte
2015-04-14, 20:03
Hello Malte,
Could you please comment on my following findings (to see if they ring any bells) ?
1. When i'm inside the ROM collection browser and i press Start (Joybutton9) on my controller instead of Joybutton2 to start a rom, i will be returned to the Kodi Main menu and Rom collection browser will no longer start (it seems to have crashed?). Any ideas whats causing this?
2. Always when i return from playing a Rom (emulator closed down), the Rom Collection browser will show the "filter" and search options first no matter which key (up, or down) i press.
I always have to leave this filter menu first to get back to my Rom selection and this is pretty annoying. Is it possible to disable the filter menu?
I have been running into those 2 for a long time, would be great i could fix it on my htpc!
2015-04-18, 06:28
Maybe some here knows the answer.
How can I add roms to the collection without rescraping all the data (front,back,art etc) I have all the artwork etc already. I just want to import it as is.
2015-04-18, 10:46
(2015-04-18, 06:28)thadcastle Wrote: [ -> ]Maybe some here knows the answer.
Greetings,
I hope this helps.
set the scrapers to local data (make sure you have the paths all setup first)
2015-04-20, 07:20
caffeinepills Wrote:Is there anyway to hide the command prompt that pops up?You could try to use Popen as launch option.
caffeinepills Wrote:I also seem to be having a problem with anything saving. Things like solo mode or use Popen I check and save, then go back into settings to find the option unchecked again. Neither seem like they do anything. Hell I can't even delete rom collections anymore, it will clear the window. I'll re-open Rom Collection Browser and there are all the games again.... I don't understand.This is an issue with your skin. As a workaround you could switch to Confluence to make the changes and then back to your skin (I guess Aeon Nox or MQ?).
Tyme Wrote:When I add different Rom collections they seem to be importing properly. The only issue i am having is when i go into game launch options the rom collections are not separated into different consoles.I guess it is a skin issue again. There is a Rom Collection selection at the top of the Edit dialog. If this is empty you should try to make the changes with Confluence and then switch back to your original skin.
ie: I imported my NES roms first then SNES then PSX etc... the problem with this is I can only change the launch parameters for my NES collection in Launch Options.
I can provide a screenshot if I explained my problem badly.
codygs83 Wrote:The first issue is when I first launch rcb as its loading my Roms it freezes kodi. I have a little over 100 Roms including nes, GB, Sega, n64, and nds and its freezing at random points loading the list of roms.Can you show me a log file?
I've tried looking though settings for an option to turn off regarding reloading the list every time rcb opens but don't see anything to help.
codygs83 Wrote:Other issue is the error opening .7z files. I've looked around and see that in the past installing rcb from a repo has been the culprit. I've tried installing rcb directly from the latest zip and even tried older versions and nothing will open .7z files.Problem is that RCB does not have the latest 7z libraries that match the current python version. It is on my list to provide them.
ldavet Wrote:I'm having problems with missing text in RCB. In the box that asks you which collection to import roms into, which scrapers to use, etc., the text of the options is missing in Aeon MQ (both 5 and 6). I've also seen missing text in Aeon Nox. Works fine in Confluence, though.This is a skin issue. I have to ask the skinners that they update their RCB skin files.
mlu3141 Wrote:Is it still working? I am having a similar problem where it will scrape my collection and add them to the database, but nothing shows my library. Should i keep rescanning and hope it just randomly shows up?Please show me a log file after you tried to scrape games.
jonesad24 Wrote:Is there a guide on how to install this on an Android tv box rather than windows?Here is a thread about running RCB or Advanced Launcher on Android. But the RCB part is outdated. In RCB it should be enough to install your emulators on Android and then run RCB and create your config file. If your emulator is supported by RCBs autoconfig option everything should run out of the box. You can check all supported emulators here.
omgiafs Wrote:For beginning, one old bug (on Android - 100%):I can't reproduce this issue on my windows machine. What skin are you using?
If i scroll gamelist by mouse (mouse wheel, mouse cursor), nothing happens: black background screen, no game info, no year, etc., but game title changes. But if i scroll with gamepad (Xbox 360 controller) all works fine. There is a bug with input methods, i think.
omgiafs Wrote:Second big-big problem: latest versions of Kodi Helix 13.0(1,2) and RCB are awfully slow when work together.Same as above. Everything is ok on my PC. Do you have this issue with all scripts or just RCB?
When i click to launch RCB, it starts after 10 or more seconds. All RCB menus are slow too. This is very bad. Add this to bug, described upper, you get very ugly program with no chances to use it.
And with slow working scripts (all python scripts, i think) we must wait TWO DAYS to scrape collection of 300 GAMES :facepalm
I tried latest Gotham, Frodo releases and i can say that latest Gotham release work wery fast with latest RCB release.
Device: android 4.4 TV-box with wired mouse, wired XBox 360 controller and airmouse, if it information can help.
NessPJ Wrote:1. When i'm inside the ROM collection browser and i press Start (Joybutton9) on my controller instead of Joybutton2 to start a rom, i will be returned to the Kodi Main menu and Rom collection browser will no longer start (it seems to have crashed?). Any ideas whats causing this?This is an old bug. I know that I already worked on it but I can't remember if I ever managed to fix it. I re-added it to my list.
NessPJ Wrote:2. Always when i return from playing a Rom (emulator closed down), the Rom Collection browser will show the "filter" and search options first no matter which key (up, or down) i press.Same as above. This only happens with certain views (I guess Info 2 view) and does not occur in other views. No idea why this happens.
NessPJ Wrote:3. I would like to add some Dos games to my Rom collection browser using DosBOX. Is there a guide somewhere on how to do this properly? Preferrably i would like to learn what sort of commandline i need to set up so the emulator starts with the right speeds, sound settings and mounted locations. I found this build which also supports the use of save states.Did the tips of ldavet solve this problem?
darkmeiun Wrote:just started experimenting with the RCB and noticed it lacks couple of things, the game language (flag icons would be grate) and version of the game some console games have revisions and prototypes are available at least i did not find any option for that in the wikis (skinning section) that there even is an option to add those into the view without extra coding for RCB, any plans on making those? or should i start learning xmlIt is on the list to add this info but it is nothing that is planned for the next releases. It is not only xml. You will need to add these options in RCBs database and enable the scrapers to fill it properly.
aquiles2k Wrote:Just saw that when scraping an GBA game with thegamesdb the request contains "platform=Nintendo%20Gameboy%20Advance".This fix needs to be done in config.py / consoleDict. I guess you know what to do?
This results in "<Error>The specified platform was not valid.</Error>".
Correct platform would be "Nintendo%20Game%20Boy%20Advance".
Daeymon Wrote:Any skins for this which make RCB more friendly for touch devices? Trying to use the Filters on Android is a bit of a nightmare.Not that I know of. Had this issue myself when trying to use it on my Android phone. Planned for the future but may take some time.
riggs1973 Wrote:Hi guys is there a way to set the collection to panel view? every time i reopen it i have to change it manuallyUsually RCB should save the last viewstate and reopen the view that you had selected when you closed RCB. But this does not work per Rom Collection. It is one setting for the whole program.
2015-04-20, 13:18
Hello all,i was just wondering if it is possible to add more skins to RCB?
edit : i just found out it is possible,i'm a user of aeon nox for xbmc,i dont understand how to add it to rcb..any help plz?
i use kodi 14.2 on android system
2015-04-20, 16:51
@ malte like omgiafs wrote I seem to be having a problem with slow menus , I think its to do with the video snaps. if I enable debug mode I can see the fps drops to 0 frames then menu seems to stick until video resumes playing
not sure if its anything to do with
15:23:05 T:8388 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
15:23:05 T:5500 NOTICE: RCB_INFO: onAction: 4
15:23:05 T:7964 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
15:23:05 T:7964 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
15:23:06 T:5500 NOTICE: RCB_INFO: onAction: 4
15:23:06 T:7964 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
15:23:06 T:7964 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
15:23:06 T:8388 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
15:23:07 T:8388 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 1
15:23:07 T:7964 DEBUG: CSaveFileStateJob::DoWork - Saving file state for video item H:\MEDIA\AAE\Video\elim2.mp4
15:23:07 T:8388 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
15:23:07 T:7964 DEBUG: Loading settings for H:\MEDIA\AAE\Video\gravitar.mp4
15:23:07 T:7964 DEBUG: CPlayerCoreFactory::GetPlayers(H:\MEDIA\AAE\Video\gravitar.mp4)
2015-04-22, 03:58
I cannot launch my wii emulators through RCB. When I open a terminal and type..
everything works fine.
My RCB config.xml has...
To troubleshoot I opened a terminal and typed "kodi". Kodi launched and I went to RCB and selected the rom I wanted to used and it would not launch. The terminal said....
Where the heck did these forward slashes come from?
/usr/bin/dolphin-emu-cli -e /path/to/rom.iso
<emulatorCmd>/usr/bin/dolphin-emu-cli</emulatorCmd>
<emulatorParams>"-e %ROM%"</emulatorParams>
<romPath>/storage/roms/wii/*.iso</romPath>
<romPath>/storage/roms/wii/*.wbfs</romPath>
sh: \/usr\/bin\/dolphin\-emu\-cli: No such file or directory.
2015-04-22, 11:36
(2015-04-22, 03:58)necbot Wrote: [ -> ]Code:sh: \/usr\/bin\/dolphin\-emu\-cli: No suck file or directory.
Can you provide the kodi logfile from such a try?
2015-04-23, 03:08
Here is my kodi log file...
01:01:30 T:139888407136256 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:01:30 T:139888407136256 NOTICE: -----------------------------------------------------------------------
01:01:30 T:139888407136256 NOTICE: Starting Kodi (14.2 Git:Unknown). Platform: Linux x86 64-bit
01:01:30 T:139888407136256 NOTICE: Using Release Kodi x64 build
01:01:30 T:139888407136256 NOTICE: Kodi compiled Apr 13 2015 by GCC 4.9.2 for Linux x86 64-bit version 3.18.5 (201221)
01:01:30 T:139888407136256 NOTICE: Running on Arch Linux 0.0, kernel: Linux x86 64-bit version 3.19.3-3-ARCH
01:01:30 T:139888407136256 NOTICE: FFmpeg statically linked, version: 2.4.6-xbmc-2.4.6-Helix
01:01:30 T:139888407136256 NOTICE: Host CPU: AMD A8-7600 Radeon R7, 10 Compute Cores 4C+6G, 4 cores available
01:01:30 T:139888407136256 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
01:01:30 T:139888407136256 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
01:01:30 T:139888407136256 NOTICE: special://masterprofile/ is mapped to: /home/necbot/.kodi/userdata
01:01:30 T:139888407136256 NOTICE: special://home/ is mapped to: /home/necbot/.kodi
01:01:30 T:139888407136256 NOTICE: special://temp/ is mapped to: /home/necbot/.kodi/temp
01:01:30 T:139888407136256 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
01:01:30 T:139888407136256 NOTICE: Local hostname: htpc
01:01:30 T:139888407136256 NOTICE: Log File is located: /home/necbot/.kodi/temp/kodi.log
01:01:30 T:139888407136256 NOTICE: load settings...
01:01:30 T:139888407136256 ERROR: PulseAudio: Failed to connect context
01:01:30 T:139888407136256 NOTICE: PulseAudio might not be running. Context was not created.
01:01:30 T:139888407136256 NOTICE: Found 1 Lists of Devices
01:01:30 T:139888407136256 NOTICE: Enumerated ALSA devices:
01:01:30 T:139888407136256 NOTICE: Device 1
01:01:30 T:139888407136256 NOTICE: m_deviceName : hdmi:CARD=Generic,DEV=0
01:01:30 T:139888407136256 NOTICE: m_displayName : HD-Audio Generic
01:01:30 T:139888407136256 NOTICE: m_displayNameExtra: @@@
01:01:30 T:139888407136256 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:01:30 T:139888407136256 NOTICE: m_channels : FL,FR
01:01:30 T:139888407136256 NOTICE: m_sampleRates : 32000,44100,48000
01:01:30 T:139888407136256 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
01:01:30 T:139888407136256 NOTICE: Device 2
01:01:30 T:139888407136256 NOTICE: m_deviceName : hdmi:CARD=Generic,DEV=1
01:01:30 T:139888407136256 NOTICE: m_displayNameExtra: HDMI
01:01:30 T:139888407136256 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
01:01:30 T:139888407136256 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
01:01:30 T:139888407136256 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
01:01:30 T:139888407136256 NOTICE: Device 3
01:01:30 T:139888407136256 NOTICE: m_deviceName : @:CARD=Generic_1,DEV=0
01:01:30 T:139888407136256 NOTICE: m_displayName : HD-Audio Generic (@:CARD=Generic_1,DEV=0)
01:01:30 T:139888407136256 NOTICE: m_displayNameExtra: ALC892 Analog
01:01:30 T:139888407136256 NOTICE: m_deviceType : AE_DEVTYPE_PCM
01:01:30 T:139888407136256 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
01:01:30 T:139888407136256 NOTICE: m_sampleRates : 48000
01:01:30 T:139888407136256 NOTICE: Device 4
01:01:30 T:139888407136256 NOTICE: m_deviceName : surround21:CARD=Generic_1,DEV=0
01:01:30 T:139888407136256 NOTICE: m_displayName : HD-Audio Generic (surround21:CARD=Generic_1,DEV=0)
01:01:30 T:139888407136256 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
01:01:30 T:139888407136256 NOTICE: m_sampleRates : 44100,48000,96000,192000
01:01:30 T:139888407136256 NOTICE: Device 5
01:01:30 T:139888407136256 NOTICE: m_deviceName : iec958:CARD=Generic_1,DEV=0
01:01:30 T:139888407136256 NOTICE: m_displayNameExtra: ALC892 Digital S/PDIF
01:01:30 T:139888407136256 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
01:01:30 T:139888407136256 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
01:01:30 T:139888407136256 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
01:01:30 T:139888407136256 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:01:30 T:139888407136256 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:01:30 T:139888407136256 NOTICE: Default DVD Player: dvdplayer
01:01:30 T:139888407136256 NOTICE: Default Video Player: dvdplayer
01:01:30 T:139888407136256 NOTICE: Default Audio Player: paplayer
01:01:30 T:139888407136256 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:01:30 T:139888407136256 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
01:01:30 T:139888407136256 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
01:01:30 T:139888407136256 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:01:30 T:139888407136256 NOTICE: Loaded playercorefactory configuration
01:01:30 T:139888407136256 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:01:30 T:139888407136256 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:01:30 T:139887928506112 NOTICE: Thread ActiveAE start, auto delete: false
01:01:30 T:139887920113408 NOTICE: Thread AESink start, auto delete: false
01:01:30 T:139888407136256 NOTICE: Running database version Addons16
01:01:30 T:139888407136256 NOTICE: ADDONS: Using repository repository.xbmc.org
01:01:30 T:139888407136256 ERROR: Unable to load libcec.so.2, reason: libcec.so.2: cannot open shared object file: No such file or directory
01:01:30 T:139888407136256 ERROR: Initialise - failed to initialise bus cec
01:01:30 T:139887909533440 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
01:01:30 T:139888407136256 NOTICE: Setup SDL
01:01:30 T:139888407136256 NOTICE: Checking resolution 16
01:01:30 T:139888407136256 NOTICE: Using visual 0x1f4
01:01:30 T:139888407136256 NOTICE: GL_VENDOR = X.Org
01:01:30 T:139888407136256 NOTICE: GL_RENDERER = Gallium 0.4 on AMD KAVERI
01:01:30 T:139888407136256 NOTICE: GL_VERSION = 3.0 Mesa 10.5.3
01:01:30 T:139888407136256 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
01:01:30 T:139888407136256 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_ARB_clip_control GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control
01:01:31 T:139888407136256 NOTICE: Running database version Addons16
01:01:31 T:139888407136256 NOTICE: Running database version ViewModes6
01:01:31 T:139888407136256 NOTICE: Running database version Textures13
01:01:31 T:139888407136256 NOTICE: Running database version MyMusic48
01:01:31 T:139888407136256 NOTICE: Running database version MyVideos90
01:01:31 T:139888407136256 NOTICE: Running database version TV26
01:01:31 T:139888407136256 NOTICE: Running database version Epg8
01:01:31 T:139888407136256 NOTICE: start dvd mediatype detection
01:01:31 T:139888406841088 NOTICE: Thread DetectDVDMedia start, auto delete: false
01:01:31 T:139888407136256 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
01:01:31 T:139888407136256 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
01:01:31 T:139888407136256 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
01:01:31 T:139888407136256 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
01:01:31 T:139887585355520 NOTICE: Thread LanguageInvoker start, auto delete: false
01:01:31 T:139888407136256 NOTICE: Previous line repeats 1 times.
01:01:31 T:139888407136256 NOTICE: initialize done
01:01:31 T:139887576700672 NOTICE: Thread LanguageInvoker start, auto delete: false
01:01:31 T:139888407136256 NOTICE: Running the application...
01:01:31 T:139887585355520 NOTICE: -->Python Interpreter Initialized<--
01:01:31 T:139887585355520 NOTICE: Previous line repeats 2 times.
01:01:31 T:139887585355520 NOTICE: RCB Service: Start
01:01:31 T:139887585355520 NOTICE: RCB Service: launch RCB on startup = false
01:01:31 T:139887585355520 NOTICE: RCB Service: scrape games on startup = false
01:01:31 T:139887585355520 NOTICE: RCB Service: Done
01:01:31 T:139887585355520 NOTICE: Thread JobWorker start, auto delete: true
01:01:31 T:139888407136256 NOTICE: starting zeroconf publishing
01:01:31 T:139888407136256 NOTICE: ES: Starting event server
01:01:31 T:139887299880704 NOTICE: Thread JobWorker start, auto delete: true
01:01:31 T:139887219046144 NOTICE: Thread EventServer start, auto delete: false
01:01:31 T:139887219046144 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
01:01:31 T:139887219046144 NOTICE: UDP: Listening on port 9777
01:01:31 T:139888407136256 NOTICE: Enabled Joystick: Logitech Gamepad F710
01:01:31 T:139888407136256 NOTICE: Details: Total Axis: 6 Total Hats: 1 Total Buttons: 11
01:01:31 T:139887202260736 NOTICE: Thread JobWorker start, auto delete: true
01:01:31 T:139887210653440 NOTICE: Thread TCPServer start, auto delete: false
01:01:31 T:139888406841088 NOTICE: Thread RSSReader start, auto delete: false
01:01:31 T:139888406841088 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
01:01:31 T:139888406841088 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:01:31 T:139887202260736 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
01:01:31 T:139887202260736 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:01:31 T:139887202260736 ERROR: Open - failed to open source <http://mirrors.kodi.tv/addons/gotham/addons.xml.md5>
01:01:31 T:139887202260736 ERROR: Failed to fetch checksum for directory listing http://mirrors.kodi.tv/addons/gotham/addons.xml for repository repository.xbmc.org.
01:01:32 T:139888406841088 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
01:01:32 T:139888406841088 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:01:32 T:139886749284096 NOTICE: Thread JobWorker start, auto delete: true
01:01:33 T:139888406841088 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
01:01:33 T:139888406841088 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
01:01:38 T:139887593748224 NOTICE: Thread BackgroundLoader start, auto delete: false
01:01:41 T:139887593748224 NOTICE: Thread LanguageInvoker start, auto delete: false
01:01:41 T:139887593748224 NOTICE: -->Python Interpreter Initialized<--
01:01:41 T:139887593748224 NOTICE: RCB started
01:01:41 T:139887593748224 NOTICE: RCB: sys.argv = ['']
01:01:41 T:139887593748224 NOTICE: RCB: param =
01:01:41 T:139887593748224 NOTICE: RCB: setting launchRCB = True
01:01:41 T:139887593748224 NOTICE: RCB: launchRCB = True
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Loading sqlite3 as DB engine
01:01:41 T:139887593748224 NOTICE: RCB: init log level
01:01:41 T:139887593748224 NOTICE: RCB: current log level: 2
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Path to configuration file: /home/necbot/.kodi/userdata/addon_data/script.games.rom.collection.browser/config.xml
01:01:41 T:139887593748224 NOTICE: RCB_INFO: XBMC version = 14.2.000
01:01:41 T:139887593748224 NOTICE: RCB_INFO: XBMC major version no = 14
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Init Rom Collection Browser: /home/necbot/.kodi/addons/script.games.rom.collection.browser
01:01:41 T:139887593748224 NOTICE: RCB_INFO: RCB version: 2.1.2
01:01:41 T:139887593748224 NOTICE: RCB_INFO: RCB service addon: <xbmcaddon.Addon object at 0x7f3a0c0fa580>
01:01:41 T:139887593748224 NOTICE: RCB_INFO: checkUpdateInProgress
01:01:41 T:139887593748224 NOTICE: RCB_INFO: scrapeOnStartupAction =
01:01:41 T:139887593748224 NOTICE: RCB_INFO: initializeConfig
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Config() set path to None
01:01:41 T:139887593748224 NOTICE: RCB_INFO: checkRomCollectionsAvailable
01:01:41 T:139887593748224 NOTICE: RCB_INFO: initXml
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Number of Rom Collections in config.xml: 1
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Reading config version from config.xml: 2.0.8
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Config file is up to date
01:01:41 T:139887593748224 NOTICE: RCB_INFO: readXml
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Begin readRomCollections
01:01:41 T:139887593748224 NOTICE: RCB_INFO: current Rom Collection: Wii
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Rom path: /storage/roms/wii/*.iso
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Rom path: /storage/roms/wii/*.wbfs
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Media path: /storage/roms/wii/boxfront/%GAME%.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Media path: /storage/roms/wii/boxback/%GAME%.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Media path: /storage/roms/wii/cartridge/%GAME%.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Media path: /storage/roms/wii/screenshot/%GAME%.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Media path: /storage/roms/wii/fanart/%GAME%.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper site: thegamesdb.net
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: thegamesdb.net
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper descFilePerGame: True
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper site: archive.vg
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: archive.vg
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper site: mobygames.com
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: mobygames.com
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Image Placing name: gameinfobig
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Image Placing name: gameinfosmall
01:01:41 T:139887593748224 NOTICE: RCB_INFO: emulatorCmd: /usr/bin/dolphin-emu-cli
01:01:41 T:139887593748224 NOTICE: RCB_INFO: emulatorParams: "-e %ROM%"
01:01:41 T:139887593748224 NOTICE: RCB_INFO: useBuiltinEmulator: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: ignoreOnScan: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: allowUpdate: True
01:01:41 T:139887593748224 NOTICE: RCB_INFO: useEmuSolo: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: usePopen: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: autoplayVideoMain: True
01:01:41 T:139887593748224 NOTICE: RCB_INFO: autoplayVideoInfo: True
01:01:41 T:139887593748224 NOTICE: RCB_INFO: useFoldernameAsGamename: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: maxFolderDepth: 99
01:01:41 T:139887593748224 NOTICE: RCB_INFO: doNotExtractZipFiles: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: makeLocalCopy: False
01:01:41 T:139887593748224 NOTICE: RCB_INFO: diskPrefix: _Disk.*
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: local nfo
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: giantbomb.com
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Scraper Site: maws.mameworld.info
01:01:41 T:139887593748224 NOTICE: /home/necbot/.kodi/userdata/addon_data/script.games.rom.collection.browser/MyGames.db
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Begin cacheItems
01:01:41 T:139887593748224 NOTICE: RCB_INFO: End cacheItems
01:01:41 T:139888407136256 WARNING: Trying to add unsupported control type 1
01:01:41 T:139888407136256 WARNING: Previous line repeats 1 times.
01:01:41 T:139888407136256 ERROR: Control 500 in window 13000 has been asked to focus, but it can't
01:01:41 T:139887593748224 NOTICE: RCB_INFO: Begin onInit
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin loadViewState
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showConsoles
01:01:42 T:139887593748224 NOTICE: RCB_INFO: begin showFilterControl: 500
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showConsoles
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showGenre
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Selected Console: 0
01:01:42 T:139887593748224 NOTICE: RCB_INFO: begin showFilterControl: 600
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showGenre
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showYear
01:01:42 T:139887593748224 NOTICE: RCB_INFO: begin showFilterControl: 700
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showYear
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showPublisher
01:01:42 T:139887593748224 NOTICE: RCB_INFO: begin showFilterControl: 800
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showPublisher
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showCharacterFilter
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showCharacterFilter
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showGames
01:01:42 T:139887593748224 NOTICE: RCB_INFO: helper.buildLikeStatement
01:01:42 T:139887593748224 NOTICE: showGames: load games from db in 3 ms
01:01:42 T:139887593748224 NOTICE: RCB_INFO: showGames: load 1 games to list in 5 ms
01:01:42 T:139887593748224 NOTICE: RCB_INFO: End showGames
01:01:42 T:139887593748224 NOTICE: RCB_INFO: Begin showGameInfo
01:01:43 T:139887593748224 NOTICE: RCB_INFO: End showGameInfo
01:01:43 T:139887593748224 NOTICE: RCB_INFO: End loadViewState
01:01:43 T:139887593748224 NOTICE: RCB_INFO: End onInit
01:01:43 T:139887593748224 NOTICE: RCB_INFO: onAction: 107
01:01:49 T:139887593748224 NOTICE: Previous line repeats 92 times.
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Begin launchEmu
01:01:49 T:139887593748224 NOTICE: RCB_INFO: launching game with id: 3
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Begin launcher.launchEmu
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Begin saveViewState
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Begin saveViewMode
01:01:49 T:139887593748224 NOTICE: RCB_INFO: End saveViewMode
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Begin helper.saveViewState
01:01:49 T:139887593748224 NOTICE: RCB_INFO: End helper.saveViewState
01:01:49 T:139887593748224 NOTICE: RCB_INFO: End saveViewState
01:01:49 T:139887593748224 NOTICE: RCB_INFO: files for current game: [(u'/storage/roms/wii/Mario Kart Wii.wbfs',)]
01:01:49 T:139887593748224 NOTICE: RCB_INFO: launcher.buildCmd
01:01:49 T:139887593748224 NOTICE: RCB_INFO: emuCommandLine: /usr/bin/dolphin-emu-cli
01:01:49 T:139887593748224 NOTICE: RCB_INFO: preCmdLine:
01:01:49 T:139887593748224 NOTICE: RCB_INFO: postCmdLine:
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Getting Multiple Disc Parameter
01:01:49 T:139887593748224 NOTICE: RCB_INFO: emuParams: "-e %ROM%"
01:01:49 T:139887593748224 NOTICE: RCB_INFO: rom: /storage/roms/wii/Mario Kart Wii.wbfs
01:01:49 T:139887593748224 NOTICE: RCB_INFO: No precmd created.
01:01:49 T:139887593748224 NOTICE: RCB_INFO: No postcmd created.
01:01:49 T:139887593748224 NOTICE: RCB_INFO: cmd: "\/usr\/bin\/dolphin\-emu\-cli" "-e \/storage\/roms\/wii\/Mario\ Kart\ Wii\.wbfs"
01:01:49 T:139887593748224 NOTICE: RCB_INFO: precmd:
01:01:49 T:139887593748224 NOTICE: RCB_INFO: postcmd:
01:01:49 T:139887593748224 NOTICE: RCB_INFO: launchEmu on non-xbox
01:01:49 T:139887593748224 NOTICE: RCB_INFO: screenMode: 1920x1080@ 60.00 - Full Screen
01:01:49 T:139887593748224 NOTICE: RCB_INFO: Toggle to Windowed mode
01:01:49 T:139887593748224 NOTICE: RCB_INFO: launch emu
01:01:49 T:139887593748224 NOTICE: RCB_INFO: onAction: 100
01:01:50 T:139887593748224 NOTICE: RCB_INFO: launch emu done
01:01:51 T:139887928506112 ERROR: PulseAudio: Failed to connect context
01:01:51 T:139887928506112 NOTICE: PulseAudio might not be running. Context was not created.
01:01:51 T:139887928506112 NOTICE: Found 1 Lists of Devices
01:01:51 T:139887928506112 NOTICE: Enumerated ALSA devices:
01:01:51 T:139887928506112 NOTICE: Device 1
01:01:51 T:139887928506112 NOTICE: m_deviceName : hdmi:CARD=Generic,DEV=0
01:01:51 T:139887928506112 NOTICE: m_displayName : HD-Audio Generic
01:01:51 T:139887928506112 NOTICE: m_displayNameExtra: @@@
01:01:51 T:139887928506112 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:01:51 T:139887928506112 NOTICE: m_channels : FL,FR
01:01:51 T:139887928506112 NOTICE: m_sampleRates : 32000,44100,48000
01:01:51 T:139887928506112 NOTICE: m_dataFormats : AE_FMT_LPCM,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
01:01:51 T:139887928506112 NOTICE: Device 2
01:01:51 T:139887928506112 NOTICE: m_deviceName : hdmi:CARD=Generic,DEV=1
01:01:51 T:139887928506112 NOTICE: m_displayNameExtra: HDMI
01:01:51 T:139887928506112 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
01:01:51 T:139887928506112 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
01:01:51 T:139887928506112 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_LPCM,AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC
01:01:51 T:139887928506112 NOTICE: Device 3
01:01:51 T:139887928506112 NOTICE: m_deviceName : @:CARD=Generic_1,DEV=0
01:01:51 T:139887928506112 NOTICE: m_displayName : HD-Audio Generic (@:CARD=Generic_1,DEV=0)
01:01:51 T:139887928506112 NOTICE: m_displayNameExtra: ALC892 Analog
01:01:51 T:139887928506112 NOTICE: m_deviceType : AE_DEVTYPE_PCM
01:01:51 T:139887928506112 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
01:01:51 T:139887928506112 NOTICE: m_sampleRates : 48000
01:01:51 T:139887928506112 NOTICE: Device 4
01:01:51 T:139887928506112 NOTICE: m_deviceName : surround21:CARD=Generic_1,DEV=0
01:01:51 T:139887928506112 NOTICE: m_displayName : HD-Audio Generic (surround21:CARD=Generic_1,DEV=0)
01:01:51 T:139887928506112 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
01:01:51 T:139887928506112 NOTICE: m_sampleRates : 44100,48000,96000,192000
01:01:51 T:139887928506112 NOTICE: Device 5
01:01:51 T:139887928506112 NOTICE: m_deviceName : iec958:CARD=Generic_1,DEV=0
01:01:51 T:139887928506112 NOTICE: m_displayNameExtra: ALC892 Digital S/PDIF
01:01:51 T:139887928506112 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
01:01:51 T:139887928506112 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
01:01:51 T:139887928506112 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
01:01:51 T:139887593748224 NOTICE: RCB_INFO: Toggle to Full Screen mode
01:01:51 T:139887593748224 NOTICE: RCB_INFO: End launcher.launchEmu
01:01:51 T:139887593748224 NOTICE: RCB_INFO: End launchEmu
2015-04-23, 09:00
fabeer Wrote:Hello all,i was just wondering if it is possible to add more skins to RCB?If a skin has its own rcb skin files you do not need to do anything as a user. RCB will just use the files that are provided by the skin. I am not sure if latest Nox skin still ships its own rcb files. I haven't checked for a while.
If you want to create your own skin files you should check this.
joebloggs12 Wrote:@ malte like omgiafs wrote I seem to be having a problem with slow menus , I think its to do with the video snaps. if I enable debug mode I can see the fps drops to 0 frames then menu seems to stick until video resumes playingI can't reproduce it on my system even with video playback enabled. I am on Win 7 with Kodi and Confluence.
necbot Wrote:To troubleshoot I opened a terminal and typed "kodi". Kodi launched and I went to RCB and selected the rom I wanted to used and it would not launch. The terminal said....Do you have "Escape Launch Cmd" enabled? Plesae try if disabling it helps.
Where the heck did these forward slashes come from?Code:sh: \/usr\/bin\/dolphin\-emu\-cli: No such file or directory.
2015-04-24, 20:16
Hello malte,
i got two problems with RCB.
1. Can i use RCB with retroarch? When yes how?
2. When i install RCB i got no conf. wizzard on the beginning. So i dont no how to setup my roms into RCB
2015-04-24, 20:56
(2015-04-24, 20:16)hackbird Wrote: [ -> ]Can i use RCB with retroarch? When yes how?
Look here e.g. http://slxprojects.blogspot.be/2014/05/x...oarch.html
2015-04-24, 21:16
Thx aquiles2k,
but i dont want to use it for windows.
I like to run it on openelec.
