Full Version: DTS passthrough for audio
dts passthrough works for video files but not audio files, is this normal?
You can select DVDPlayer to be used as default or try:
Simply add this line to your playercorefactory.xml file found in XBMCsystem:
<!-- DTS Audio -->
<rule filetypes="(dts|wav)" player="DVDPlayer" />
As you can see, the extensions dts and wav are the common filetypes for DTS audio files.
