Can you guys post these modded Confluence skins back up on the forum? I know a lot of data was lost from the past month during the recent site crash. Thanks.
-hogfan
Thanks for the link. From the sound of things on the main XBMC page, it sounds like the 1 month of data that is missing from the forum is not recoverable. Too bad if that's the case.
Does anybody know the following:
When I enable TV shows on the Home Menu, the backdrop image doesn't display, just a black screen. Works for everything else. Anybody else seen this and have a fix?
-hogfan
hogfan Wrote:Does anybody know the following:
-hogfan
You have to set it in skin settings
anybody knows why the little blueraydisc only show on 1080p movies and not 720p movies? Somebody know how to fix this?
I believe that is the way the resolutions are setup in the XML file. I believe 720p is setup to show up as HD-DVD and Blu-Ray is setup for 1080p. I don't have any HD sources so I can't test this myself.
hogfan Wrote:I believe that is the way the resolutions are setup in the XML file. I believe 720p is setup to show up as HD-DVD and Blu-Ray is setup for 1080p. I don't have any HD sources so I can't test this myself.
i do believe this is correct
Just went a-hunting for the horizontal mod from Jezz_X, and found the thread in Google cache.
The download link is
here.
Hopefully he won't mind me posting it.
