Full Version: [Linux] .mkv playback problems ACER R3160 Revo
Hey guys, here is a description of my problem, but first the info you need. Smile Take care, I'm quite new at linux so it's possible I did some mistakes.
# Computer: Acer Aspire R3160 Revo / 2 GB Ram / Intel Ion / connected to Philips LCD 5603D via HDMI cable
# Linux Distribution and Version - Ubuntu 9.10 desktop for 64 (Ubuntu 9.10, 2.6.31-20-generic x86_64)
# Architecture x86_64
# Install Method - Manual following guidelines on forum
# SVN Revision - couldn't find under confluence skin, if you can help me where to find it - I'll post it here
# Detailed Instructions to Reproduce the Problem:
- The first problem I encountered was huge frame loss and slow . mkv reproduction, both 720p/1080p, both over ethernet connection and wireless. This was fixed by finding a similar problem on forums and using the solution here http://forum.xbmc.org/showthread.php?p=473089 (apt-get install libvdpau1)
- the second problem I can't solve is that in the lower part of the screen, lets say the lower 1/5 (or 1/4) there is video jutter, screen tearing. I found a a solution here so I just did add-apt-repository ppa:team-xbmc-svn - update and install.
- Even though I got those new options, there is still a problem with jutter, screen tearing in the lower part. It looks like some frames there overlap for a second.
- I did try to edit my xorg.conf like noted here but that boots my ubuntu in low GFX mode.
# FULL Debug Log - debugg was enabled under Confluence skin - Sytem - Debugging - Enable Debug Logging - here is the copy paste of log http://pastebin.com/RPAKCMXv
If I can add anything else, let me know. Hope it helps!
Sounds like you have done your homework but here are a couple of suggestions.
1. Don't run the 64 bit version of karmic, run the 32 bit. You done need to be able to address 4+ GB of ram in your ion box and the 64 bit version seems to be more bug prone.
2. Don't give us on working on your xorg.conf. The tearing is most likely due to compositing and so just try disabling compositing and leave the other stuff along for now.
cbrunhaver Wrote:2. Don't give us on working on your xorg.conf. The tearing is most likely due to compositing and so just try disabling compositing and leave the other stuff along for now.
Would adding
Quote:Section "Extensions"
Option "Composite" "Disable"
EndSection
to it help?
oops. I meant don't give up, no don't give "us".
In any case, yes, you want to disable compositing by adding that to your xorg.conf.
cbrunhaver Wrote:oops. I meant don't give up, no don't give "us".
I've tried adding those few lines, however, that puts my Ubuntu into low gfx mode. Any ideas?
I'll try toying with it a bit, I think it could be a problem between display sync and xbmc, not sure.
I have the r3610 with 2GB. I run x86 ubuntu karmic and an xbmc svn dated march 1st. I am running the 190.53 nvidia drivers and have the following xorg.conf. This works fine with some settings within XBMC which I will post in a bit. I do get a few seconds of green pixelation at the start of playing an mkv file but after that its fine, be it 720p or 1080p
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder75)  Tue Dec  8 21:04:28 PST 2009
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    gamma 1.2 1.2 1.2
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    Option  "NoLogo"              "true"
    Option  "DynamicTwinView"     "false"
    Option  "NoFlip"               "true"
    Option  "FlatPanelProperties" "Scaling = Native"
    Option  "ModeValidation"      "NoVesaModes, NoXServerModes"
    Option  "ModeDebug"           "true"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Modes "1920x1080_60_0" "1920x1080_24_0"
    EndSubSection
EndSection
        Option  "Composite"           "false"
EndSection
try using this as a somewhat sane default
Section "Device"
        Identifier "nvidia"
        Driver  "nvidia"
        Option  "NoFlip"              "false"
EndSection
Section "Screen"
        Identifier      "screen"
        Device          "nvidia"
EndSection
        Option  "Composite"           "disable"
EndSection
though, on my asrock ion i have to set noflip to true, otherwise i get tearing. also make sure opengl sync is turned on in nvidia settings.
d3fiant Wrote:I have the r3610 with 2GB. I run x86 ubuntu karmic and an xbmc svn dated march 1st. I am running the 190.53 nvidia drivers and have the following xorg.conf. This works fine with some settings within XBMC which I will post in a bit. I do get a few seconds of green pixelation at the start of playing an mkv file but after that its fine, be it 720p or 1080p
Gonna give it a go since with this jutter, it's unplayable.
