Full Version: A couple of suggestions
xbmc is great a few tweaks id love to see though
in my programs view as usage show most used at bottom i reacon it should be most used at top, i know you can change that but i like changing between name and usage and the way they are laid out i have to change direction as well
on 3 nov build parent folder is on in games this doesnt look good. and if you turn off parent directies and use b to move back out of a movie folder it goes to top of list. if you use parent folder go back it goes back to were you were in the list.
i know its a nag and its small things.......but cant find any big problems to nag about
cheers
you should know where the right place for suggestions is. Cool
