Full Version: help getting xmbc to run at start on ubuntu server?
Hi!
I have ubuntu 9.10 server and i have xbmc connected to my tv. to administer i ssh from my desktop.
At the moment everytime i reboot i have to login at the server box directly to start the things i want to Sad here's how i do it at the moment:
login >
$startx (this opens a basic gui with fluxbox)
open a terminal >
$wine utorrent
open a terminal >
$get_iplayer.cgi --port=1935 --getiplayer=/usr/bin/get_iplayer $
open a terminal >
$xbmc
this starts starts basic gui, utorrent, starts an iplayer workaround to feed it into xbmc, starts xbmc.
sorry if i'm making this a bit basic and detailed but not really sure how to accomplish this in one script to use at startup? Smile
i have tried putting a few commands in /etc/init.d/local as per this tutorial
my /etc/init.d/local looks like:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
vncserver :1
startx
xbmc
cd /home/server/
./get_iplayer.cgi --port=1935 --getiplayer=/usr/bin/get_iplayer
exit 0
any help would be greatly appreciated!!
Thanx!
follow the instructions for xbmcbuntu / minimal setup. You can use the xbmc-live package to autostart the system
vikjon0 Wrote:follow the instructions for xbmcbuntu / minimal setup.
thanx! it worked by putting exec xbmc in ~.xsession i i think i'll try find some other way to load the other things Smile
