Full Version: .dds problem
I have problem with xbmc and .dds support.
My system is a Ubuntu Karmix with the last xbmc-svn and nvidia ion.
All thumbs /home/xbmc/.xbmc/userdata/Thumbnails/Video/Fanart are convert to .dds and the advancedsettings.xml with <useddsfanart>true</useddsfanart>.
But if I start xbmc, xbmc generate new .tbn thumbs.
It's this normal?
greets nubert
Fanart and Thumbs aren't the same thing.
Hi Hitcher,
but under /home/xbmc/.xbmc/userdata/Thumbnails/Video/Fanart are the Thumbnails from the Fanarts, or?
And all the others folders in /home/xbmc/.xbmc/userdata/Thumbnails/Video/ are the thumbnails.
Nubert Wrote:Hi Hitcher,
yes those are the fanarts "thumbs" you just use the word thumbs wrong.Laugh
to answer your question even if you are using dds images doesnt mean xbmc stop creating .tbn fanarts, until xbmc support the use of dds by default instead of tbn those files will always going to be created automatically just ignored them.
ok, thank you for help.
