Full Version: No VDPAU with SVN 28714
VDPAU doesn't work on my system since some SVN revisions ago, latest I tried is 28714 with no success.
I use "./configure --disable-pulse --enable-goom --prefix=/usr" with this config result
XBMC Configuration:
Debugging: Yes
Profiling: No
Optimization: Yes
OpenGL: Yes
VDPAU: Yes
CrystalHD: No
Joystick: Yes
XRandR: Yes
GOOM: Yes
PCRE Support: Yes
MID Support: No
ccache: Yes
PulseAudio: No
FAAC: Yes
DVDCSS: Yes
Avahi: Yes
Non-free: Yes
ASAP Codec: No
Webserver: Yes
Deprecated libdts: No
Deprecated liba52: No
External Libraries: No
External FFmpeg: No
External liba52: No
External libdts: No
External libass: No
External Python: No
prefix: /usr
Mainly I tried on a system with nvidia drivers version 185.18.36
Distro Ubuntu 9.10 x86
SVN 28714
xbmc.log -> http://pastebin.com/kBsDVhpD
What is render method set to?
bobo1on1 Wrote:What is render method set to?
Is set forced to VDPAU
Did you do a make distclean before compiling.
bobo1on1 Wrote:Did you do a make distclean before compiling.
Yes, and I tried to delete all and commit from scratch.
I observed some odd thing, normally before I compiled xbmc only using:
make -j8
and then sudo make install
, but now I need to:
make -j8
make -j8 xbmc.bin
make -j8 xbmc-xrandr
Is this normal?
pakojones Wrote:Hi,
make -j8
make -j8
make -j8 xbmc.bin
Is this normal?
you play with fire doing make -j8. always follow with make to be sure all has been compiled.
davilla Wrote:you play with fire doing make -j8. always follow with make to be sure all has been compiled.
I also tried to make with only one core with the same result, I need to:
make
make xbmc.bin
make xbmc-xrandr
Huh
