(2013-02-09, 22:55)roc4fun Wrote: [ -> ]My Pandora keeps crashing XBMC. New Windows 7 install. New Frodo.
The plugin logs on and gets my stations correctly. The music plays for 2 seconds and goes into infinite repeat. XBMC crashes. Here is some of my XBMC log...
Local music plays fine. Movie audio is fine. I've tried all 3 audio quality settings in Pandora with the same results. I'd love to fix this, it's my favorite!!
Dave
Is this happening all the time, what are the dns resolvers you are using?
(2013-02-10, 03:14)johnalanmichael Wrote: [ -> ]I have the Pandora script 1.28.10-Git running perfect on XBMC for Mac (still running Snow Leopard 10.6.8) & AppleTV 2 (5.0.2) XBMC Frodo, I don't know why anyone is having trouble with this on these two at platforms least. Having said that, I've installed XBMC on my iPad Mini & iPhone 4S but the same Pandora script will not run on these two and I can't figure out why. I've removed all scripts from the appropriate locations and have even installed a couple different Pandora scripts as described on this or the previous pages posts and neither work. Anyone have any ideas? It's not necessary to have Pandora in XBMC on either iPad or iPhone with PandoraSkip from Cydia, but I like to get things working across the board.
Is there anything showing up in the logs, does it login, can you see the stations?
Hey everyone, newby to XBMC here! Loving it so far and getting everything set up well and kinks solved. Just had a question about this addon.
I installed with the zip file provided in the yaktab link a few posts ago. It installed fine, I'm able to log in fine, and I see all my stations. When I select one, nothing happens. No music plays, it doesn't appear that anything's loading.
Thanks for any help! I'd love to have pandora working on my XBMC.
Zotac Zbox ID80, 4Gb ddr3, 120Gb 7200rpm, external 1Tb WD usb3.0
XBMCbuntu 12.0 Frodo
(2013-02-13, 23:19)AkAxtion Wrote: [ -> ]Hey everyone, newby to XBMC here! Loving it so far and getting everything set up well and kinks solved. Just had a question about this addon.
See post
http://forum.xbmc.org/showthread.php?tid...pid1256516
Thanks K3oni! I reviewed this thread but not In its entirety... obviously.
I've got it set on mp3high; what a simple fix. I should've tried the different settings before posting. I appriciate the help and the plugin!
No it will not log in. I have not looked at the logs, not even sure how to do that. I'm somewhat proficient with this stuff, but I haven't attempted to look at the logs, how would I do that? Sorry.
A little guidance please, I have downloaded the script to my ATV2 and installed from ZIP version
1.2.10 and when I go to 'music addons' I see Pandora, but when I click on it I get 'Script error'!
I would appreciate any help in knowing what I have done wrong and what I need to do to fix it. I am running XBMC Frodo.
Anybody out there with any help? :-)
I am also getting a script error loggin in with Frodo. Here is my xbmc log.
19:37:16 T:2808079456 NOTICE: -->Python Interpreter Initialized<--
19:37:16 T:2917745760 NOTICE: PleXBMC Helper -> PleXBMC Helper has started
19:37:17 T:2808079456 NOTICE: PANDORA: Initializing v1.2.10-git
19:37:17 T:2808079456 NOTICE: PANDORA: sys.platform = linux2
19:37:22 T:2808079456 ERROR: EXCEPTION: XML File for Window is missing
19:37:22 T:2808079456 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: XML File for Window is missing
File "/storage/.xbmc/addons/plugin.xbmc-pandora-vtwoodss-xbmc-pandora-pithos/default.py", line 246, in <module>
panda = Panda()
File "/storage/.xbmc/addons/plugin.xbmc-pandora-vtwoodss-xbmc-pandora-pithos/default.py", line 99, in __init__
self.gui = PandaGUI( "script-pandora.xml", scriptPath, self.skinName)
RuntimeError: XML File for Window is missing
-->End of Python script error report<--[/php][/code]
I too am also getting this. Today was the first time I tried. No go with a working script of this?
(2013-02-16, 03:33)eroslawsk Wrote: [ -> ]I am also getting a script error loggin in with Frodo. Here is my xbmc log.
panda = Panda()
(2013-02-19, 01:22)A.D.I.D.A.S Wrote: [ -> ]I too am also getting this. Today was the first time I tried. No go with a working script of this?
Where did you get the version from, please look a couple pages back for a version i posted and try that one.
That is the one I'm using. The one you posted.
(2013-02-19, 03:41)A.D.I.D.A.S Wrote: [ -> ]That is the one I'm using. The one you posted.
Ok, what is the error in the error log, did you open the settings page to set the settings and account details?
(2013-02-19, 03:46)k3oni Wrote: [ -> ] (2013-02-19, 03:41)A.D.I.D.A.S Wrote: [ -> ]That is the one I'm using. The one you posted.
How do I pull the error log?
I will also regrab your file and try again.
Here is my log file, hope it can tell you something.
Quote:21:29:47 T:3037931264 DEBUG: ExecuteXBMCAction : Translating RunAddon($INFO[Container(9000).ListItem.Property(Path)])
21:29:47 T:3037931264 DEBUG: ExecuteXBMCAction : To RunAddon(script.xbmc.pandora)
21:29:47 T:3037931264 INFO: initializing python engine.
21:29:47 T:3037931264 DEBUG: new python thread created. id=10
21:29:47 T:2821708608 NOTICE: Thread XBPyThread start, auto delete: false
21:29:47 T:2821708608 DEBUG: Python thread: start processing
21:29:47 T:2821708608 NOTICE: -->Python Interpreter Initialized<--
21:29:47 T:2821708608 DEBUG: Process - The source file to load is /home/adidas/.xbmc/addons/script.xbmc.pandora/default.py
21:29:47 T:2821708608 DEBUG: Process - Setting the Python path to /home/adidas/.xbmc/addons/script.xbmc.pandora:/usr/share/xbmc/addons/weather.wunderground/resources/lib/wunderground:/usr/share/xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/adidas/.xbmc/addons/script.common.plugin.cache/lib:/home/adidas/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gst-0.10:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:/usr/lib/python2.7/dist-packages/ubuntu-sso-client:
21:29:47 T:2821708608 DEBUG: Process - Entering source directory /home/adidas/.xbmc/addons/script.xbmc.pandora
21:29:47 T:2821708608 DEBUG: Instantiating addon using automatically obtained id of "script.xbmc.pandora" dependent on version 1.0 of the xbmc.python api
21:29:47 T:2821708608 NOTICE: PANDORA: Initializing v1.2.10-git
21:29:47 T:2821708608 NOTICE: PANDORA: sys.platform = linux2
21:29:47 T:2821708608 DEBUG: DialogProgress::StartModal called
21:29:47 T:2821708608 DEBUG: ------ Window Init (DialogProgress.xml) ------
21:29:47 T:2821708608 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
21:29:47 T:2869787456 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xaa700468
21:29:47 T:2821708608 DEBUG: DialogProgress::StartModal called (already running)!
21:29:48 T:2869787456 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xaa700468
21:29:49 T:2821708608 DEBUG: Previous line repeats 1 times.
21:29:49 T:2821708608 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xa4b8b990
21:29:49 T:2821708608 ERROR: EXCEPTION: XML File for Window is missing
21:29:49 T:2869787456 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0xaa700468
21:29:49 T:2821708608 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "/home/adidas/.xbmc/addons/script.xbmc.pandora/default.py", line 246, in <module>
panda = Panda()
File "/home/adidas/.xbmc/addons/script.xbmc.pandora/default.py", line 99, in __init__
21:29:49 T:3037931264 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
21:29:49 T:2821708608 INFO: Python script stopped
21:29:49 T:2821708608 DEBUG: Thread XBPyThread 2821708608 terminating
21:29:49 T:3037931264 DEBUG: waiting for python thread 10 (/home/adidas/.xbmc/addons/script.xbmc.pandora/default.py) to stop
21:29:49 T:3037931264 DEBUG: python thread 10 (/home/adidas/.xbmc/addons/script.xbmc.pandora/default.py) destructed
21:29:49 T:3037931264 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
21:29:54 T:3037931264 DEBUG: Previous line repeats 10 times.
21:29:54 T:3037931264 DEBUG: ------ Window Deinit (DialogKaiToast.xml)
